Power window problem, Just happened!! please help!!
I GOT IT!!!!
I GOT IT!!!! It happened to be the - accessory delay fuse - even though I checked every fuse 3 times, this fuse was not completely blown. Hence the reason the radio was going off then on every other time I turned off and on the car. Now what made it blow in the first place was that a I discovered that the previous owner had two wires that ran from the radio and the battery for an amp in the trunk, that were poorly taped on the end with the wire exposed.:nonono: :bang: :chair: After I found the problem I removed the unused wires and replaced the half blown fuse everything went back to normal!!!! YAY!!!:D
I had the same exact problem however as soon as I replaced the fuse it blew so....
I left the key in the 'on' position and replaced the fuse, it did NOT blow and the windows are working now!!!
