My window motor got stuck once... down.. in a rain storm. I ripped the door panel off, jiggled the motor around a bit (trying to figure out how to remove it) and it worked fine after that. Probably could have just kicked the door and had the same effect. If you listen really close down by the door speaker you should be able to hear the solenoid clicking when you press the button, then at least you know you have power and the button works.
