power windows
91mini
115
Twice now my driver window rolled almost all the way down and then up a little and stopped at about the midpoint. How did I do that? Was it and accident or is there a way you can press the botton to make it do this?
Heard the reason ford stopped putting the "windows-down" function of the active security key FOB was because the windows would just roll themselves down every now and then. Might want to take it to the dealer and have that function turned off, if your stang is an earlier build. If not, no idea...
windows would roll down any time water gets in lock causing an open switch . acording to my dealership . ford said they tried filling locks with grease but after while water would just get back in . pearsonally i woud rather have the security then have that feature still on my car
I have the Global Window Down feature and the only problem I have ever had was due to a friend messing with the calibration. The window would close and then open again without any control. I fixed it once I acted on the procedure listed in the manual.
-Dan
