predator problem with 99 mustang
Bad Saleen
116
predator problem with 99 mustang, im not able to disable the speed limiter my friend car cut at 110 mph and when i go inside the tuner i select off but each time it s again set at on, after all the time i reinstall the tune and it never want to be off what is that ?????????
mine does the same thing...i set it to off and nothing changes. i wrote predator an email and they responded that mustangs don't have speed limiters...i must've talked to an idiot tech. anyways, i need to call them but haven't gotten around it yet. i use my speed limiter as a sanity check when some guy tries to race me on the highway!
110? That's the limiter for a V6 Mustang. Are you sure you got the right Predator for the right car? I'm not sure if there are different models of the Predator for different models of mustangs. I know it goes by year, though. You should check that out.
the reason mine is at 110 is becuase the guy i bought the car from got it with the crappy 16 inch wheels stock becuase he immediately bought the cobra r wheels. they were governed like the v6 mustangs becuause the tires were not rated for higher speeds.
before i installed my predator tune i had put that little speed needle down to 145-150 mph going form L.A to Phoenix i just did it to see where my car would top out at so when i saw that it would that i was cool with it since i will never take the car up to that speed but i havent meesed with the speed limiter so i dont know what the steps are :shrug:
