Predict Cam Characteristics...
NicD
57
0.510/0.534 222/223 @ 0.50" 112 lobe sep
How would this cam act in a N/A 347 with AFR 185's in terms of:
1. Idle
2. Performance
3. Emissions
Thanks in advance...
Is the 347e smog legal? Sounds like a smog legal cam to me.
As a general rule big duration and passing emissions don't go together. Once the overlap gets to the point where it causes a rougher idle (which everyone seems to want) it will be tough to pass.
Exactly - 347e is their smog legal stroker...
I'm using this as a starting point to try to determine how much bigger i can go and still be smog legal...Any ideas?
Those specs aren't bad for a "street car".
I would go with a little more valve lift (.550 area) and kept the duration and lsa right where it is. The 185's flow peak around the .550" lift area.
The idle will have a little lope to it, so you will know the engine has a cam, but not at all too choppy.
It will make power from about 1800-5800 and shouldn't have a problem passing emissions.
It sounds like a good street cam to me ... although point specific numbers don't tell the whole story of the lobe profile.
Good Luck
If you need to stay smog legal all you can really play with is the lift. However, this may still have an affect on emissions as the ramp rates will probably change.
It may be better to bump to a 114lsa if opening the lift and/or duration? I am by no means an expert though. I am just throwing the idea out to see what others think. I suppose that if going for max power in an emissions legal combo one would have to look more closely at the exact valve timing events, as opposed to the very general duration at .050" and max lift numbers.
In terms of idle and performance, what would be the difference between a cam with 230/235 dur and .535 lift with 1.6 rockers vs. a cam with 230/235 duration with .568 lift with 1.7 rockers?
Again this is for a daily driver...
You could put a higher ratio rocker like 1.7's to get a higher lift. I have a custom cam i just took out of my stock block 302 w/ afr's. The lift was around .580 and i didn't have clearence issues. Also, it would not come close to passing emissions no matter what i tried.
Why spend THOUSANDS on a 347 only to put a junk guessing game camshaft in?!!?!?!!?!?! Put the RIGHT cam in to give you what you want. I can tell you my custom FTI cam is MUCH bigger and it drives awesome.
That cam has a lot of lift for that duration. Truthfully, the AFR 185 will flow almost the same with .500 lift and .534 . Other than the fairly high lift, that cam might as well be a broomstick for a 347. I realize that CHP builds a lot of engines but that doesn't sound like the greatest cam. I even question the LSA. It's quite short for a motor that will naturally make power down low. That souns like a cam for a smaller motor that needs more tq- sooner than later. Just me thinking.......
It's not a guessing game, more of a learning game...Even if I had FTI do a custom cam, I'd still want to know the specs and I'd still want to understand what was going on and why my car performs the way it does...
BTW, I've have chatted with Mr. Curtis, he'll likely be doing my cam once my combo is complete, but the motor will possibly be going in with stock intake and exhaust...This cam will likely be temporary, but in the car while doing final mods...
As far as cams go, I understand the concepts but not the applications - that is - from reading, I know what lift, duration and lobe separation are, but I don't know how they relate to idle, power, and emissions...
It's kinda like knowing what passes, runs, and 1st downs are, but not having any idea how to put a drive together for a touchdown...Some guys are satisfied watching the hits and the great plays...I want to know what made the plays work...
Can anybody maybe refer me to some reading material? Maybe provide a link? I've searched quite a bit but haven't come up "cams for dummies" yet...
