Prev Owner Removed Control Arm Bushings
  • Thread starter Thread starter danny g
  • Start date Start date Oct 7, 2012
danny g
375
Oct 7, 2012
  • Oct 7, 2012
I am in the process of rebuilding my rear suspension. Previous owner had put on aftermarket upper and lower control arms. I have everything disassembled. As I am removing the old springs I notice something odd. The contorl arms have no bushings. Just rattling around loosley with the bolt hold ing them in. That explains the part of the crappy/noisy ride on the way home from buying the car. Now I need new bushings. I picked up some stock ones at autozone. Problem is they have a metal sleeve eround them. They would fit if I somehow got them out of the sleeve. Any ideas?
boostfrk
712
69
59
Colorado
Oct 7, 2012
  • Oct 7, 2012
Not a good way I know of. I've always heard to buy the bushings without the metal sleeve which is what I did when I replaced mine.
Is the metal sleeve still in the control arms that are currently on the car?
gearheadboy
1,425
177
84
Greencastle Pa
Oct 7, 2012
  • Oct 7, 2012
Ya I don't know if Auto Zone bushings would even fit aftermarket control arms. I'd replace the arms. They are cheap. If you mean the axle housing ones, I'd remove the old sleeve from the housing and install the new bushing with the sleeve on it.
2000xp8
SN Certified Technician
Aug 8, 2003
8,027
1,618
194
NJ
Oct 7, 2012
  • Oct 7, 2012
You sure that you don't have control arms with heim joints?
Rear control arms with no bushings would have a ridiculous amount of play.
You wouldn't even be able to control the car.
I agreed with gearboy, buy new control arms.
Take some pics of what you have, but so far it sounds like you have double adjustables that are just worn out.
danny g
375
Oct 7, 2012
  • Oct 7, 2012
Yes, there is no sleeve and a ridiculous amount of play. I am pretty shocked. On the drive home I noticed it would pull to one side with even a moderate amount of throttle. and the suspension made alot of clanking noises. I knew the shcks and struts wre blown. The guy had blown tokicos, eibach springs, and tubular conrtol arms with no bushings (non adjsutable). I took your advice and just ordered some sve upper and lowers from late model resto. I got new springs and shocks and quad shocks already.
Reactions: gearheadboy
danny g
375
Oct 9, 2012
  • Oct 9, 2012
ok, so all of the control arms are off. Except one of the upper ones where it attaches to the frame. There was no bushing in it. Just a bolt and metal sleeve rattling around in there. I got the nut off one end but it seems bolt is fused to the sleeve so it won't unscrew. I think i can fit a small locking plier in there to hold the sleeve while I unbolt it. Vant find my vise grip so I'll pick one up on the way home. I think my only other option is to crank up the sawzall and try to cut through the sleeve and bolt. Any other ideas?
2000xp8
Aug 8, 2003
8,027
1,618
194
NJ
Oct 10, 2012
  • Oct 10, 2012
Just sawzall it, i've had the same thing happen on the bushing on shocks before.
95Vert383AOD
1,133
34
69
New Bedford, MA
Oct 10, 2012
  • Oct 10, 2012
Can you use a screw driver to tap the bolt out from the other side????or stick something like a screwdriver under the head of the bolt while turning it with a vise grip on the sleeve. Lots of spray lube works too.
Admin Dude
Jan 4, 1985
43,083
21,267
234
Box behind Walmart
Oct 10, 2012
  • Oct 10, 2012
^this^
Theres no reason to try a surgically remove those bolts. They're junk regardless if they come out in 10 pieces or just 1.
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
5K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
C
1965 Mustang Lower Control Arm Question.
  • chopper1876
  • Nov 9, 2024
1965 - 1973 Classic Mustangs -General/Talk- Dec 7, 2024
GOvert
G
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Suspension What Control Arms Are These?
  • Mhalc1
  • Jun 6, 2023
3K
Fox 5.0 Mustang Tech Jun 7, 2023
rednotch
