Priming oil system? HELP!
OinkAodeOink
3,026
Daytona bch, Florida
Trying to prime a new motor, so we are cranking it over with the spark plugs out and the coil packs unplugged. Problem is we are not seeing any oil pressure on a guage we hooked into the oil filter housing.
The starter is kicking over the flywheel (finally) and the battery appears to have a strong charge. What can I do next to figure out if the oil pump is good. This is a brand new shortblock with a new high flow oil pump.
Any thoughts or suggestions would be really appreciated.
Thanks, Mike
I thought modulars didn't require oil pump priming. :shrug:
In any case, how long are you cranking for? Takes a while usually to build it up.. I would imagine perhaps even more in a brand new engine.
ok well I tried out the fertilizer sprayer with no luck.. Guess the oil is too thick to pick up. I dont think you can send presurized oil into that port and expect it to make its way into the pickup, and oil pump ( feed side).. Atleast I had no luck trying it this way...
Im stuck
