Pro Kit + caster chamber
02'MineralGT
43
I ordered the eibach pro kit, but is it nessecary to use caster chamber plates? Ive heard people talking about alignment problems after installing casters, with the pro kit am i going to ned caster plates??? thanks alot for any info.
The pro kits don't drop you as much. I have the H&R Super Sport springs which drop about 1.9" front and 1.5" rears which is a pretty large drop, and therefore, Chicane Sport Tuning recommended that I get caster/camber plates. But I know many people with Steeda Sport Springs and Eibach pro-kits who don't use caster/camber plates and don't have a problem with alignment (both springs I believe drop 1.5" front).
With the pro's most people don't need CC plates. However it is a good idea to have them in case you do. I did my pro's and left the CC in the trunk took it to a good alignment guy he checked it out and it was right in spec. So I got CC's I don't need right now, but if I had to use them I had them.
You can try aligning them without the c/c plates. I have the FRPP B springs on my 98, and it doesn't need them (1" drop). But on my 04 with Steeda Sport Springs I did have to get them. BTW, I got the MM ones.
I put the Eibach Pros on mine and still was able to use the stock plates. However, a realignment was needed and it was just barely within factory spec.
