probably the dumbest question ill ever ask
alright its not that big of a deal, but im starting to get annoyed. Why isnt my windshield wiper fluid coming out when i try to clean the windshield? The reservoir is full, i can hear the sound of air pushing out when i put my ear next to the nozzles where the fluid should come out, and theres no leaking anywhere. wtf??
bad multifuntion switch or bad washer fluid pump..
First thing you need to do to test this is get to the washer fluid pump connector and see if you have power and ground there when somebody hits the switch for you..
If you do have both then the motor is bad, if not check the multifuntion switch and see if you have power leaving the multifuntion switch..
most common cause of this concern is a bad multi switch.. second most common is the pump motor.
