Problem again!
  • Thread starter Thread starter MUSTANGJOE
  • Start date Start date Sep 23, 2005
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 23, 2005
  • Sep 23, 2005
Great! ...in the beggining of summer I spent $1000 installing my clutch, gears and fixing my oil leaks and tranny leaks. Now its leaking all over again!!
to top it of my tranny crossmember is broken. Its gonna cost me $1100 to fix everthing including taking down the tranny and resealing it. I hate leaks...!
oil leak seems to be coming from the real main seal which i replaced a couple months ago. I a leaking tranny a sign of it giving up? also I seem to be losing power..can a bad tranny do this?..Thxs
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Sep 23, 2005
  • Sep 23, 2005
Once a car starts leaking it's hard to get them to stop... Leak paths and such.
maybe there is a better rear main seal that will help you seal up your motor.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Sep 23, 2005
  • Sep 23, 2005
Try the Fel-Pro teflon RMS. Use some silicone sealant between the block and the RMS. Did you use sealant or loctite on the flywheel bolts??
D
dyb003
68
  • Sep 23, 2005
did you lube the seals before you put them in? Its always a good idea to put some sort of silicone lube or a little greas on the seal to prevent dry start up that can overheat the seal and distort it or rip it untill it get the regular oil on it to keep it lubed. This should be done on anly seal that has a moving part going through it. I have done this on all engines I have worked on at the dealership and home and never had a problem, but not doing it, I have had to re-do them. just my opinion. good luck. I hate oil leaks to.
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 23, 2005
  • Sep 23, 2005
Hey guys. I made sure when the shop changed the rear seal to lube it first..but if they really did it I don't know.
I will ask then if they put at tipe of lock tight on the flywheel.
I hate spending money on this kinda stuff...its no like I'll get any horse power after all this nor will I see a difference in the ride...Its just stupid but important things to do I guess!..trying to keep myself from not punching
someone! ........
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Engine New Oil Leak Help.
  • Slo5Oh89
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 19, 2025
Slo5Oh89
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
