I'm in the process of installing my new combo. I got the cam in and it degree'd perfectly right off the bat. So I proceeded with checking the valve train geometry. I first put some clay on the piston to check the piston-valve clearance as I checked lifter preload, two birds with one stone.
I bolted up the head over the #1 cylinder without torqing. I installed an intake and exhuast rocker. I turned the engine to load the lifters and let them bleed down for 5-10 min. before checking the preload. I checked the preload and it was pretty high since I had the heads milled. I threw on a .060" shim on both and they both check out between .030" and .040" preload. Everywhere I check, the allowable is .020" to .060" but I did read somewhere that is had to be .020" to .030" I'm not sure if this is the case
Ok so I took off the head and checked the clay. Seems good. I had at least .125" clearance but I don't what the allowable is?
So with the geometry looking ok with the shims, I installed all the rockers, torqing them down alittle more every few minutes as the lifters bled down. I finished at 20 ft-lbs. I re-checked the preload and it only increase by alittle, so it seems ay-okay.
Now this is where I started to get worried and this leads to my big question. I noticed that *some* of the springs were compressing too much. I figure .060" should be ok, but they were going down to .024"
But I noticed that it was becuase those particular lifters weren't completely bled down. OK so now I'm so confused! Here is the big question . . . how where does the lifter sit during operation?? Does it pump ALL the way up, or does it stay half way bled down or what? I'm not going any further until I know I won't destroy the motor once this fires up. If I need new springs, fine. BUT now how do I correctly check the p-v clearance
and what is the allowable p-v clearance anyway? I'll be talking to the engine builder this week about it, but I'm pretty sure I could get some expert help here too.
When I checked the total lift at the spring with the bled down rocker, it was at .357" or so which is obviously waaaay low. So is the lift going to pump up by .176" for a total lift of .533"? If so, the p-v clearance is wack.
Here is what I'm putting in:
- Fully worked GT40's
- Comp Cams 270H-R10 cam (.333 lobe lift, int/exh, built in 4° advance (106° ICL)
- Proform 1.6 rr's (so .533 total lift)
- Stock pushrods - I have an adjustable pushrod checker in case I need it.
But I noticed that it was becuase those particular lifters weren't completely bled down. OK so now I'm so confused! Here is the big question . . . how where does the lifter sit during operation?? Does it pump ALL the way up, or does it stay half way bled down or what? I'm not going any further until I know I won't destroy the motor once this fires up. If I need new springs, fine. BUT now how do I correctly check the p-v clearance When I checked the total lift at the spring with the bled down rocker, it was at .357" or so which is obviously waaaay low. So is the lift going to pump up by .176" for a total lift of .533"? If so, the p-v clearance is wack.
and $12 of my own, so no biggy on the cash yet.
