  • 1994 - 1995 Specific Tech
Problem checking p-v clearance with our lifters! (long)
  • Thread starter Thread starter Zero Signal
  • Start date Start date Jan 8, 2006
First Prev 2 of 2
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jan 9, 2006
#21
  • Jan 9, 2006
  • #21
Killercanary said:
I did it the way Nate mentioned. He was wrong about one thing though (sorry Nate!).
This is correct except for the TDC comment. The distance will actually be closest a few degrees before (on the exhaust valve since the piston is chasing the valve as its closing) or after it (on the intake valve since the intake valve is chasing the pistons as it goes down) TDC (around 15* if memory serves me correctly). Its been a while so if I'm wrong on this you can yell at me Nate! Its best to check it at MULTIPLE degrees as the closest PTV clearance will NOT be at TDC, but rather a few degrees before or after it.
You're right Paul , i think i misworded myself. I didnt mean that it would be closest at TDC. I forget the exact "pattern" of the intake and exhaust valves but i did probably take like 20 readings. Once u get the hang of it, its super easy and doesnt take ANY time at all.
:SNSign:
Zero Signal
2,633
Tucson, AZ
Jan 9, 2006
#22
  • Jan 9, 2006
  • #22
Yeah. That much I did know It looks like summit has the oil pump primers. I'll order one of those since they are still pretty cheap.
First Prev 2 of 2
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Y
Engine Oily cylinder- bad lifter relationship
  • Yoyoda
  • Nov 9, 2024
Fox 5.0 Mustang Tech Nov 16, 2024
Yoyoda
Y
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Lifter tick
  • Creomod
  • Sep 4, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 6, 2021
Creomod
