Problem since gear install, again... experts please.
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
Okay now that a tranmission guy fixed the whinning in the gear (shimming issues) I have another issue that needs to be fixed and the guy had no idea from where the heck it was coming from. I'll try to be as clear as possible; everytime I run into a small or big "wave" in the road something in the rear just grinds on the road. When i'm alone in the car it's not that bad (I weight 180lbs) but as soon as we'r two in the Stang it's hell, almost every small wave makes a damn insane grind noise coming from the rear. Two mechanos checked it and couldnt find anything grinding.. what the heck could it be ? I can provide some pictures or videos tomorrow during the day if it can help in any ways.
Thanks for the help, those gears install already cost me a crapola of money :mad:
EDIT:
Found the problem, it's the d/s rubbing on the e-brake brackets since the cable was changed... problem is how to fix it w\o buying anything else ? Hammer ?
-Damned
Are the bushings on the upper and lower control arms good? When I bought my car they were shot and the rear end was moving back and forth a little. Didn't know it when I test drove it cuz it was very low on gas and only had me in it. When I filled the tank up and took my buddy for a ride it started making a grinding noise from the driveshaft scraping when the rearend would move. On mine it only happened during acceleration.
The guy checked everything under and he said the shocks were in very good condition. It's doing that since the 1st guy, who knows nothing, tried to install the gears... Is there anyway I could picture the bushing or something to know if it's fuxxed ? I don't know alot about mechanics
thanks
I think Joe (Urban) is on the right path. If your driveshaft isn't rubbing on anything, also take a look at the clearance between your tires and tailpipes. I did a half assed job putting my stock exhaust back on for an emissions test, and every left turn I take, my tailpipe rubs on the tire.
94-302-vert said:
sounds like your stock steel d/s is rubbing on the e-brake cable bracket...
Tadam.
You got it right i'm pretty sure because the guy who fuxeed up my gears changed my whole e-brake cable i'm pretty sure he did something wrong there tho... what can i do to fix it and make sure its this ? It wasn't doing it before the new e-brake cable.. anyway to fix it except scrap the e-brake !?
