Problem starting 2002 GT
mode101
202
Dallas, TX
I recently purchased a 2002 GT vert. The car has an intermittent problem starting. I turn the key, it cranks, but does not start. Sometimes after cranking for a few seconds, when I let the key go, it will decide to start, and spit/sputter to life.
I thought it might be the gas, or fuel filter. I have changed gas, gas stations, gas grades, and replaced the fuel filter. Still the same thing.
It does this maybe 1 out of 5 times to start it.
I did a search on this problem and found a few older threads with people reporitng the same thing, but did not really find a fix. I did notice that a lot of people with this problem had 2002 GTs.
I am open to any suggestions.
Thanks!:)
I think it's a common problem for the car to take longer to start when warm.
I notice my car that if i try to start my engine when hot after shutting it off for a few mins it will take a few extra seconds of cranking to get it fired and sometimes it stumbles. It happens rarely but it's embarrassing.
Doesn't happen often enough to make me take it in though. I seemed to have "cured" the problem by cycling the key once or twice before cranking it
Not sure if that's the same prob you are having
i have the exact same problem. Nothing to worry about except that it is embarassing when it has to crank a bunch of times and then barely sounds like it started. Mine only does it when the engine is warmed up. The cure that i have found that has solved my problem 100%, (not saying it will work for everybody) is turning the key to the on position and letting that dinging sound go for about 4 times and then crank it over. Since i started doing that, it has never given me that problem again. I got this tip from somebody on here that had the same problem and it worked for them also. BTW i also have a 2002.
By turning the key to the on position for a few seconds and that seems to correct the problem makes me think its the fuel pump. When you turn your car to the on position, can you hear the fuel pump come on?
Is the fuel pump in the gas tank on this car?
thanks!
I'm having the exact same intermittent problem on my '02 GT 'vert. Although, I hadn't noticed that it does it when the engines warm. I seem to remember someone else on another forum mentioning that they had the same problem and solved it by cleaning the EGR valve? :shrug: I'll give the key "on position" option a try.
had the prolem forever, there is no fix. turning the key didnt help mine. yea it more of a hot start. notice it when it happens, it will be right afetr you run in the store real quick or when you get gas.
mine seems to have went away on its own in all the mods ive done.
I have the same problems....after it's been running for awhile I stop to go grab something come back and I'd say 80% of the time it will start with no problems, sometimes it will sput alittle bit..stumbling to fire but does. Oddly enough I do the same thing that was mentioned about keeping the key on the on position for alittle bit, and that seems to help. I figured that sensor or part doesn't flip on as quick as the key turns. Sucky part is nobody seems to know what the problem is. My best guess is something related to the fuel system. Clean your MAF is the only thing I can think of to check. I also believe that problem along the way either people with new Fuel Injectors and Fuel Pump that and possible a different tune have better luck. Don't seem to hear many people have this problem with a Diablo or SCT tuner. What sucks is being in the staging lanes of the drag strip....when you want to turn your car on and off to keep the engine cooler.
This seems to be a 2002 Mustang GT only thing. I HAD the same problem as well. It'd start fine in the morning when cool. But while warm, it wouldn't start quickly. For example, I would make a quick stop to get some gas. I try to start the car to leave and it would "choke". Yeah, it was embarrassing at times.
But the problem went away after installing the KB! Maybe it's because I changed the fuel injectors, I dunno?
Just another reason why I think it's something with the Fuel injectors, that and or the stock tune. The funny thing is, if it was really something faulty in the fuel system parts, you should notice something while you are driving the car. Hesitation, poor idle etc. which I don't experience anything. Maybe Ford wanted that old school starting feel, you know a nice carb'd engine when starting up it doesn't sound like it will but once the gas get primed in the engine it does LOL.
i have the same problem with mine when i run into a store a come oout to leave its stumbles when i start but i also noticed that if you cycle the key a few times it doesnt happen. i thought ive seen a fix for it im gonna try to find it.
I have an 04 GT and had the same problem and took it to Ford . They said the starter had a bad spot in it and replaced the starter. I only had 8K, so it was a brand new starter.
i think something similar happens to me. when my car is warm, and i try to start it, rarely i have to keep the key on longer or try twice and when it catches, its kinda slow and it takes a while for the rpm;s to get to the normal idle. what i usually do now, is i crank it for the usuall amount and if its kinda sputtering to get to idle rpm, i rev the engine/blimp the gas, and it goes back to normal. i have an 01 btw.
98 gt here, every once in a while after turning the key my won't start, i have to press and hold the gas to keep it going, will die if i stop pressing the gas, then all of a sudden, i can hear something kick on and it will idle by itself
mode101 said he changed gas and the fuel filter and had no luck, those were my guesses, but later he's guessing fuel pump, is there an adjustment to a fuel pump, something to clean, or is it just replace it?
thanks
I have an 02 and also posted about this problem. Only trouble code I was getting was a fualty cam position sensor so I replaced it and it still did it, 3 ford techs later the ALTERNATOR was replaced and PROBLEM SOLVED!
