  • SN95 4.6L Mustang Tech
Problem Starting?
  • Thread starter Thread starter bullitt07
  • Start date Start date Sep 30, 2007
bullitt07
  • Sep 30, 2007
Hello everyone,
I've got a 2001 bullitt, 49,XXX miles, just got it a few weeks ago. About one in every twenty or so times I try to start the car, it turns over for about four seconds and just wont start, then it starts right up one the second attempt. Sometimes it will also just barely start after the four or five seconds of turning over, as in , run at 300-400 RPM instead of jumping to the normal 900-1000 rpm idle ( or w/e is "normal"). It will run at 300-400 then after a second, jump to normal RPMS. The motor is turning over, but its just not cranking. I dont know what would cause this problem? I'm really lost? The car runs like a top other than that.
the98stang
2,408
Clovis, CA
Sep 30, 2007
  • Sep 30, 2007
bullitt07 said:
Hello everyone,
This could be a fuel pressure problem. Check the fuel pressure at the rails to see if the fuel pump is going out. Fuel injectors might also be clogged. When is the last time you changed the fuel filter?
bullitt07
  • Sep 30, 2007
I just got the car a few weeks ago, so I havent changed it. Is is hard? I'm going to change the oil next week, so if its not to difficult, i'll change it aswell. And possibly buy some fuel injector cleaner?
2000fordstanggt
404
Westland, MI
Sep 30, 2007
  • Sep 30, 2007
the only fuel injector cleaner that actually works is lucas.
heres for the fuel filter change
http://www.bullittarchive.com/1009.htm
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Sep 30, 2007
  • Sep 30, 2007
i would check IAC also
sometimes if you upshift and the rpm's are low (1200-1500) does the car seem to bog down more than normal?
Stus99GT
75
VA
Sep 30, 2007
  • Sep 30, 2007
This is a common problem with the Bullitts. Nothing to worry about. Do a search on IMBOC.com for more info.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Sep 30, 2007
  • Sep 30, 2007
Very common Mustang problem. Mine does it from time to time. Usually holding the key to on, waiting for the fuel pump to cycle and then starting it helps.
I beleive the problem is IAC related.
scupking
1,186
Enfield, CT
Sep 30, 2007
  • Sep 30, 2007
It's your IAC, mine would do the same thing on humid days. It would start but stall. If I kept my foot on the gas it would stay running till I let off. Some times just like you it would idle at around 250 rpm. I replaced the IAC a few weeks ago and all is good.
bullitt07
  • Sep 30, 2007
damn, well I've been trying the key in on position for the past 8 or so starts and havent had a problem yet. maybe that was it?
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
