  • SN95 4.6L Mustang Tech
Problem with EEC not recognizing Key
  • Thread starter Thread starter Phoenix00GT
  • Start date Start date Jul 28, 2004
P
Phoenix00GT
245
Bay Area, CA
Jul 28, 2004
  • Jul 28, 2004
I am having this problem where my EEC is not acknowledging my keys as being valid and as a result, the engine won't turn over...cranks like normal, but won't start. And while it's doing this the little "THEFT" light in the gauge pod flashes. In any event I took it in to the dealer on Monday morning and they told me it was my aftermarket alarm system interfering with the TAPS system. They disconnected the alarm's ignition kill and the car started several times yesterday afternoon and evening. Then this morning, when I was trying to get to work, it did the same thing all over again. So I had it towed to another dealership and they are looking at it now.
Has any one else experienced this problem? Do you know what the cause is and/or how to fix it?
Thanks.
saxman9801
241
Boise Idaho
Jul 28, 2004
  • Jul 28, 2004
Hey man what kind of aftermarket alarm did you have put in? Does it have remote start? There is no reason why a standard alarm would interfere with the pats system, when you put the starter disrupt in it actually cuts the starter wire so the engine will not crank at all. Either the ring that senses the chip in the key is bad ( if you have remote start they could have disrupted this) or they did a bad job splicing into the ignition wire, if this wire is loose the car would still crank but not start, two things to check, have you had anything else done to the car recently? Let me know if you need more help Dan
GT-03
630
  • Jul 29, 2004
Under the slim chance the first dealer was right, why not have had it towed to the aftermarket alarm place?
H
huesmann
332
  • Jul 29, 2004
You do mean "PATS" don't you?
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Engine Ccrm?
  • Andresquintana.mma
  • Aug 26, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 27, 2024
AeroCoupe
D
Electrical Manual 2003 GT 4.6L coupe that will not start. Thoughts? Resources?
  • DapperFish
  • Jan 17, 2024
SN95 4.6L Mustang Tech Jan 22, 2024
PSKSAM2
P
