  • 1994 - 1995 Specific Tech
Problem with FMS wires
  • Thread starter Thread starter BackDraft 5.0
  • Start date Start date Mar 25, 2007
BackDraft 5.0
11
  • Mar 25, 2007
I recently purchased a pair of 9mm FMS wires for my 1995 GT, and I seem to have a little bit of a problem. I have not tried to install them yet, but the short coil wire does not seem to fit anything because it has a projection comming out of it, and one end is bigger than the other. Here is a picture to help you visualize what I am seeing. Is there just something I don't know, or will I just have to use the long, obnoxious coil wire? Thanks.
chaos254
467
NJ
Mar 25, 2007
  • Mar 25, 2007
there are 2 coil wires included with the FMS wires...one is for our cars(yes, it is the extremely long one that you basically have to wrap around the engine bay lol) and the other one isn't.
blksn955.o
3,263
st.louis mo 314
Mar 25, 2007
  • Mar 25, 2007
I kinda cheated
I bought a "custom length" kit but used the factory boots for the coil so it bolts up stock, I even matched up the factory coil wire length. I then boxed up the rest of the "custom length" wires and took them back saying the boot style would not work on the car and bought there FMS ones.
It took about 15-20min and an extra trip to the store, but its like stock. The color is alittle off (the coil wire is alittle glossy) but matches well enough and looks 10x's better at the boot anyway.
HISSIN50
34
129
Mar 25, 2007
  • Mar 25, 2007
LMAO: "the projection coming out".
Can you hold the plug boot and pull on the wire to make the projection recede?
Good luck.
blksn955.o
3,263
st.louis mo 314
Mar 25, 2007
  • Mar 25, 2007
Good luck.
wow that sounds alittlebitgay.
1TallMF
955
Montreal
Mar 25, 2007
  • Mar 25, 2007
yup. I had the same problem. I ended-up wraping the long wire around the coil and kind of under the upper intake. Been on there for a year now. I want to get different ones soon though. Still debating between MSD and Taylor wires.
95strokerPSU
986
Sacramento from Philly
Mar 25, 2007
  • Mar 25, 2007
You can just switch the plug ends on the two coil wires. That's what I did and it worked fine.
Leeroy697
2,294
Detroit, Michigan
Mar 25, 2007
  • Mar 25, 2007
Just make your own. Takes a min and looks better than having it snaked around the car.
JJ95GTID
1,141
Phoenix, AZ
Mar 25, 2007
  • Mar 25, 2007
X2
Same here. It is easy to do
trav_19
810
Jackson, MI
Mar 26, 2007
#10
  • Mar 26, 2007
  • #10
how do you switch the ends because im getting a set soon and i dont want a mile long coil wire lol
hollywoodstang
1,095
Mar 28, 2007
#11
  • Mar 28, 2007
  • #11
OMG, It's not so bad. just hide it find the spot. and add lots of chrome stuff on the engine bay so the attention would go there. LMAO
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Rally-Pac Wiring
  • Sparksteam
  • Oct 14, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 15, 2025
Sparksteam
  • brandyn200
  • Jun 20, 2026
AeroCoupe
L
2001 cobra sequential tail lights
  • lking78
  • May 26, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 14, 2026
lking78
L
R
Need a little help identifying this plug
  • redlineracing1328
  • Oct 7, 2025
1994 - 1995 Specific Tech Oct 8, 2025
revhead347
