problem with pistons
  • Thread starter Thread starter 67rcks
  • Start date Start date Aug 1, 2008
67rcks
373
Aug 1, 2008
  • Aug 1, 2008
I got my pistons back from a motor shop today. They put new pistons (with new wrist pins) to old connecting rods. About half of them seems pretty tight (wristpin to piston) while the other half seems quite loose (e.g. piston won't stay level if holding it up). One or two connecting rods are furthermore little offset, about .05" ie they are not perfectly in the middle of the wrist pin.
Do connecting rods have to be in the middle of the wrist pin? Is it normal that new pistons would have such big tolerance? These are speed-pro brand I got from summit not the best quality or cheapest ones. Can it be somehow fixed or it's a trash?
D
D.Hearne
11,730
south louisiana
Aug 2, 2008
  • Aug 2, 2008
Sounds like you need to find a better machineshop to do you work. Pins should be centered in the rods, pin to piston clearance should be the same for all. I'd also bet some of the pistons are installed backwards too.
bnickel
5,640
lubbock, texas
Aug 2, 2008
  • Aug 2, 2008
i agree with D, take them to another machine shop and see what they think. i hope they didn't heat the pin end of the rod with a torch like a lot of people seem to do....that always seems to me like they are screwing with the metalurgy of the rod. i've always used a hydraulic press to press them in myself. i've seen a lot of rods come apart at the pin end and you could easily tell that someone used a torch to install the pins because of the buing that's always present from hetaing the rods with a torch. whether or not that was the actual cause of the rod breaking or not i can't really say but it does make me nervous to see that.
D
D.Hearne
11,730
south louisiana
Aug 2, 2008
  • Aug 2, 2008
The older machine shops sometimes used a heater to heat the pin end, that would be preferable to a torch, at least the heating would be evenly done. But I'd prefer a pressed fit without the heat too.
67rcks
373
Aug 2, 2008
  • Aug 2, 2008
He did not do anything with pistons, just heated rods + pressed new wrist pins (he had some laser thermometer to control heat). And today it turned out that a few of them have pin about 0.030" shorter than the distance between piston clips so pin+conn rod slides inside the piston. well are these pistons trash?
D
D.Hearne
11,730
south louisiana
Aug 2, 2008
  • Aug 2, 2008
As long as the pins are centered, you're fine. The rod & pin need to have lateral movement in the piston to function. Just as long as the pin doesn't slide in the rod.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Aug 2, 2008
  • Aug 2, 2008
I agree with "D" but I like full floating pins. I would have had the bushings honed for a full float and not worry about pin centering, less stress on rod to.
On a 302- 351 the rod to piston relationship is,
With the piston notch or arrow facing toward the front of motor the numbers on the rodsand caps should face to the outside of the block. 4 one way and 4 the other way.
bnickel
5,640
lubbock, texas
Aug 3, 2008
  • Aug 3, 2008
the rods also have a slightly larger chamfer on side of the big end for the fillet on the crank, this side goes to the outside edge of the crank and the smaller chamfer on the rods face each other.
67rcks
373
Aug 3, 2008
  • Aug 3, 2008
Your bet is right. 1-4 are installed backwards. If I had a shop press I would do it by myself. Now I can only hope my crank is machined right... have no plastigage to check it.
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
9
Brakes Rear brakes feel stuck after replacing pads and rotors
  • 99stanggtvinx
  • Aug 31, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 1, 2024
nickyb
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
M
  • mnky99
  • Sep 5, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
