  • 2005 - 2009 Specific Tech
Problem with revving in neutral
  • Thread starter Thread starter aggietubagod
  • Start date Start date Jul 20, 2006
1 of 2 Next Last
aggietubagod
10
Las Cruces, NM
Jul 20, 2006
  • Jul 20, 2006
I have an 06' GT with a standard, and whenever I shift to neutral, the car will just start revving up to 3,000 RPM's. I could be cruising at 800 in 5th, but the minute I shift to neutral to coast to a stop sign, it starts revving. Has anyone else had an issues with this? I'm gonna try taking it to the dealer soon, and have it looked at, but if anyone has any ideas.
OneFastCat
North Dallas, Texas
Jul 20, 2006
  • Jul 20, 2006
Something's not right. I have an '05 GT manual tranny and have no such issues. See your dealer quick.
iskwezm
4,159
20
79
Rowland Heights,California
Jul 20, 2006
  • Jul 20, 2006
my idle will raise to about 1000-1200 at a stop or after cruising for a while
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jul 20, 2006
  • Jul 20, 2006
time to check the TPS.
aggietubagod
10
Las Cruces, NM
Jul 20, 2006
  • Jul 20, 2006
bigcat, pardon my stupidity, but TPC? Thanks to all those who've posted. At least I know not to just overlook it
bigcat
May 1, 2005
3,015
7200 feet
Jul 20, 2006
  • Jul 20, 2006
tps = throttle position sensor
aggietubagod
10
Las Cruces, NM
Jul 20, 2006
  • Jul 20, 2006
thanks
REDFIRE 05 GT
283
Junction City KS
Jul 20, 2006
  • Jul 20, 2006
I had the same problem once, check the floor mat mine was shoved up under the gas pedel and was making it rev?
aggietubagod
10
Las Cruces, NM
Jul 20, 2006
  • Jul 20, 2006
It's odd, if I push the clutch in, the RPM's drop to 1000, but if it's in neutral by itself, it's at 3000. I'm about go adjust the mats and see if that helps
aggietubagod
10
Las Cruces, NM
Jul 22, 2006
#10
  • Jul 22, 2006
  • #10
An update for any of you that care. I ran it by the local ford dealership, and was told this is normal operation for the mustang. It's supposed to have high RPM's.
He insists that it is only because the car only has 2000 miles
nycstang37
146
Queens, NY
Jul 22, 2006
#11
  • Jul 22, 2006
  • #11
thats not normal, i have an 06 gt manual tranny, it doesnt rev to 3 grand in neutral. i have about 850 miles on it in case that means anything to ya, dont know when your problem started.
bigcat
May 1, 2005
3,015
7200 feet
Jul 22, 2006
#12
  • Jul 22, 2006
  • #12
i call better go to a different dealer.
anthony05gt
1,262
Maryland
Jul 22, 2006
#13
  • Jul 22, 2006
  • #13
Did they even scan the pcm? I know mine does not do that!
jberylec
81
#14
  • Jul 23, 2006
  • #14
My '06 GT/5spd has never done this! That dealer is crazy for telling you this!!
T
The Fang
602
Tallahassee Fl
Jul 23, 2006
#15
  • Jul 23, 2006
  • #15
Ahh The Infamous Revving in Neutral Problem
Ahh The Infamous Revving in Neutral Problem. There is already a couple of threads about this mostly on the v6 models. I have concluded that the dealers are dumbarses and can't do nothing for it cause they can only use a factory tune.
I ran an experiment a while back by disconnecting the tranny sensor (VSS)and low and behold it actually cured the problem but you cant go with out a speedometer. If you noticed when you push the clutch in then the revs will drop off, Once again I hint at a fricked up tune
So it seems that ppl with SCT tuners and have custom tunes don't have this problem. When my warrenty is out I'll be tuning mine only 16000 miles to go.
Sad aint it, U pay 25k for a car that revs up when your coasting next to some hot babe in a camaro.
Edit:http://www.allfordmustangs.com/forums/showthread.php?t=45776
aggietubagod
10
Las Cruces, NM
Jul 23, 2006
#16
  • Jul 23, 2006
  • #16
Got the car back last night, and the dealer still claims the same thing. However, it's not doing it anymore, one of their tests appears to have corrected the problem, at least temporarily.
It's kinda funny, they admit the problem on report, says, "test drove, verified concern. TSB says says car should be at 6000 in neutral." Apparently, they think I'm stupid since this is my first standard I wish I knew someone higher-up at Ford to ask about it, sure would be nice when I get the stupid satisfaction survey back from this dealer.
If it acts up again, I'll take it to another dealer.
bigcat
May 1, 2005
3,015
7200 feet
Jul 23, 2006
#17
  • Jul 23, 2006
  • #17
WTF??????? 6000 rpm in neutral?? what a bunch if idiots!!
T
The Fang
602
Tallahassee Fl
Jul 23, 2006
#18
  • Jul 23, 2006
  • #18
He must have ment 600 but there aint no tellin
aggietubagod
10
Las Cruces, NM
Sep 20, 2006
#19
  • Sep 20, 2006
  • #19
Here we go again
Just thought I'd let everyone know it's doing it again. Except it's worse this time, pushing in the clutch doesn't help. My car shakes quite violently when shifting into first gear at 4000-6000 RPMS. The dealership now can't find this issue, so they gave me this cool looking to sensor to push to record the data of when it's doing it so they can find it.
I removed the floormats and haven't turned cruise on to help pinpoint the problem, anyone have any other ideas?
bigcat
May 1, 2005
3,015
7200 feet
Sep 20, 2006
#20
  • Sep 20, 2006
  • #20
WOW, i didnt think it would even go into first at 4000 RPM.
1 of 2 Next Last
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
