Problem with starting car when hot
ramjetlx
212
Honolulu, Hawaii
My car starts up fine when its cold. However after running it and its hot, it wont start unless I pump the gas pedal /and or turn the ignition on and off a few times. The entire ignition system has been replaced, I just replaced the distributor last week. Im guessing its the fuel system. Anybody have any ideas whats causing this problem? Any help is greatly appreciated....
when it is hot and does not want to start, try cycling the key a few times before trying to crank it over - this will prime the pump multiple times. If this helps, check fuel pressure in the hard-start circumstances - it might be low.
good luck.
I guess we should ask: My impression was that the car cranked fine when the car would not start - it just would not catch.
From the replies, it seems like people think it does not crank when hot.
So i guess we should ask which is it?
The distributor is brand new, only a week old. Timing is set at 14 degrees. Before the car would start up fine. I do prime the pump and pump the gas pedal, it starts up after a few tries. Guess I will check the ECT sensor. I will post any changes. Thanks for everyones help!!!
ramjetlx said:
I know!!! Thats why I thought maybe it has something to do with the fuel system?
flooring the gas pedal while cranking kills the injector pulse, which is useful when there is a flood condition.
stock injectors?
good luck.
