  • SN95 4.6L Mustang Tech
Problems after changing pads on 03' GT
  • Thread starter Thread starter 87_stang
  • Start date Start date Jan 14, 2012
87_stang
131
Tonganoxie, KS
Jan 14, 2012
  • Jan 14, 2012
Last weekend I changed all 4 pads on my wifes car and cleaned off the sensors (ABS light was on, and still is). With the car on stands and in gear the rear wheels didn't want to stop while braking. We bled the lines and all is good there but still not stopping like it should. I am at a stand still right now and can't figure it out. While driving you have to push the pedal almost to the floor before the car stops. But once the brakes to kick in they seem to work normally. This is the first time I've seen/changed pads on a screw in type of caliper so not sure if I done something wrong or what. Any ideas are greatly appreciated.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jan 14, 2012
  • Jan 14, 2012
Make, year, model?
trinity_gt
3,125
81
99
Canada
Jan 14, 2012
  • Jan 14, 2012
I believe you've still got air in the lines.
Were the hydraulic lines disconnected when the pads were changed and if not, why were the brakes bled?
How was the pedal before the work began?
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Jan 14, 2012
  • Jan 14, 2012
My sentiments exactly, I'm wondering if he got air in the master-cylinder, if so hes gonna need to bench-bleed the Master- Cylinder.
D
darkside03gt
851
Sacramento CA
Jan 15, 2012
  • Jan 15, 2012
Why did you have to bleed the system?
It sounds like you have air in the master cylinder. All you have to do to bleed it is put a hose on the bleed screw closest to the firewall and bleed it. Then do the same on the next screw.
JhMustangGT03
57
Louisville, KY
Jan 16, 2012
  • Jan 16, 2012
definetly sounds like air in the lines. I would start from scratch and bleed the system.
TylerByers18
110
Grand Prairie, TX
Jan 16, 2012
  • Jan 16, 2012
did you get the rotors resurfaced if they are very glazed it can feel like the car is not stoping
Brute03
232
  • Jan 16, 2012
when i first got my car the rear brakes were hardly doing any braking and the pedal was almost hitting the floor. i bled it at the calipers and no change, it wasn't until i bled the rear screw on the m/c when i got full braking back
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
R
For Sale 2008 Mustang Bullitt for sale Richmond Hill, ON, Canada L4C 0S3
  • ROHDRNNR
  • Jun 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Jun 10, 2026
ROHDRNNR
R
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
