PROBLEMS FINALLY FIXED!!!!!!!!!!
Bosko5.0
1,067
longwood, FL
when i bought my 95 GT vert. back in october it had some issues rough Idle, transmission leak,overdrive speed approx. 42transmis112,000 miles
A month ago 118,000 miles rough idle, bad vibration, transmission fluid on underside of car/ need I say more, overdrive speed 32
well just got car back this morning turns out rough idle caused by a bad harmonic damper i mean it was comming apart(rubber piece in between the two metal pieces coming out on both sides, tranny leak was the rear housing gasket which caused the lower overdrive speed.
when i got the car back the vibration was gone(need to adjust timing though)
I couldnt even tell when it shifted it was so smooth thank goodness for TRUTECH!
I would also reccomend any one with over 80,000 miles on car to check the dampner look at it from underneath for a clear view if rubber is coming out of it replace it, it can cause timing to be inacurate, and engine inbalance which can lead to your crank being riped apart.
I just love how it feels like it doesn't have any load/no pull but when I give it some gas its gone like a rocket:D
i bought a ford racing dampner and if it last more than 2 years thats fine wit me i plan on new engine, its too bad the damper didnt totaly come apart and shoot through the hood and destroy the engine so i have a reason for a new hood and engine:D
I'll have to check mine out. I have a pretty rough idle...but I have a e303 cam, auto, and stock tune. So thats probably why lol.
My aode shifts pretty good but it does feel funny. But I have heard stock aode's don't shift the best.
