  • SN95 4.6L Mustang Tech
Problems Installing projector headlights
  • Thread starter Thread starter bpoutlaw4
  • Start date Start date Apr 17, 2004
bpoutlaw4
Baldwin Park, California
Apr 17, 2004
  • Apr 17, 2004
Im having problems getting a set of projector headlights to fit my 97 gt.
Can any one help me out with some instructions?Do i have to modify anything?
BO94ZA4
364
Vance AL
Apr 17, 2004
  • Apr 17, 2004
Yes, you have to open the stock cage up behind the headlight assem. because it only has room for the original single bulb. The projector splits this up into two bulbs (low beam and high) and the cage will not clear.
Shane98GT
65
  • Apr 17, 2004
Like he said. Get out your saw...
Trick98GT
246
Pensacola, FL
Oct 5, 2005
  • Oct 5, 2005
um...no. My one piece projectors fit right into my 98.
DropTopPony
Noob Slayer
2,570
south jersey
Oct 5, 2005
  • Oct 5, 2005
I guess the original poster needs to specify what he is useing. My 2 piece had to be custom fit.
If he is useing the 2 part headlight assembly he will have to cut out a section. Very easy to do. I went to Home Depot and bought one of those special Drill Bits that cuts sideways for @ $5. It made quick work of the job. Dremel will also work. Your lights should have had instructions and a template for the cut out. Also make sure you get them angled properly and get the Sylvania Silverstar bulbs! I actually lost visability when I installed my Projectors. I have since swapped them out for Cobra clears..
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
