  • SN95 4.6L Mustang Tech
problems with pi
  • Thread starter Thread starter gt281ci
  • Start date Start date Nov 14, 2004
G
gt281ci
14
mass
Nov 14, 2004
  • Nov 14, 2004
i recently did the pi swap to my 97 gt, i got everything done and when i started my car it fired up for like a second, so i figured that because it sat for awhile it might take a few tries. the second time i started it did the same, but then heard a noise which turned out to be a ***** load of oil pouring out of somewhere on the engine(i dont know where) i have know i dea wher this would come from but if any mechanics have any idea please enlighten me because i am at my wits end with this pi swap!
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 14, 2004
  • Nov 14, 2004
did you plug the back of the heads. there are open plugs for oil galleries.
CanadaStang
2,093
Mb
Nov 14, 2004
  • Nov 14, 2004
Did you remember to check the back of the heads to see if all the plugs were in? If that were the case, I would think it should still start though.
CanadaStang
2,093
Mb
Nov 14, 2004
  • Nov 14, 2004
Damn BDCardinal, you beat me to it.
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 14, 2004
  • Nov 14, 2004
who cares, keep posting.
you did remember to switch all the galley plugs off the old heads right?
G
gt281ci
14
mass
Nov 14, 2004
  • Nov 14, 2004
yes i did, im sure it wont hurt to check again, would there be anything else? everything was hooked up correctly but maybe i missed something
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 15, 2004
  • Nov 15, 2004
valve cover gaskets, they did slip out when i tried to put them on
CanadaStang
2,093
Mb
Nov 15, 2004
  • Nov 15, 2004
Is the oil coming from the back of the motor?
CanadaStang
2,093
Mb
Nov 15, 2004
  • Nov 15, 2004
Is there a lot of oil? Or just some? If there is a lot of oil it has to be coming from somewhere where there is pressure, like the oil sending unit. Or the plugs on the back of the heads.
Editamn, I gotta start proof reading before I hit send.
G
gt281ci
14
mass
Nov 15, 2004
#10
  • Nov 15, 2004
  • #10
it looks like its coming from the back of the motor and the valve cover gaskets are clean
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 15, 2004
#11
  • Nov 15, 2004
  • #11
use a mirror and a flashlight and try to see where its coming from. there might be a plug that wasnt put in.
CanadaStang
2,093
Mb
Nov 15, 2004
#12
  • Nov 15, 2004
  • #12
Sorry man, that really sucks.
G
gt281ci
14
mass
Nov 15, 2004
#13
  • Nov 15, 2004
  • #13
this is the ultimate headache, i should just buy a new cobra
H
HIGDON
241
Ft. Hood, TX
Nov 15, 2004
#14
  • Nov 15, 2004
  • #14
Hmmm, the only source of oil back there under pressure is the plugs, however oil from the vc can pour out rather nicely (don't ask how I know that). As far as the motor not running for more than a few seconds, go back over the engine and make sure all you vac. lines and sensors are connected. I fired my headswapped car up today for the first time. It would start at first, but I could hear compression (open headers) I checked the fuel shutoff, pressure at the lines, all my sensors, vac. lines, etc... I then stared right at the EFI harness bulkhead connector and remember the mental note I gave myself to tighten it. Didi that and it fired right up and idled like a champ. You'll get it.
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
New motor help. First start successful. Now will not turn over.
  • SavStang
  • Jun 1, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2025
SavStang
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
