problems
  • Thread starter Thread starter T.J.'s88GT
  • Start date Start date Jun 7, 2006
T
T.J.'s88GT
Bois D'Arc MO.
Jun 7, 2006
  • Jun 7, 2006
I built the engine for my 88 about 2 years ago and have'nt really driven it much. well I fired it up a couple of days ago and it has a miss in it. after I drive it for a few miles it goes away, but if I put my foot in it it starts again? just wondering if anyone has any clues?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 7, 2006
  • Jun 7, 2006
weak wire or plug or even the dizzy has some corosion in it. take off the cap and have a look.
T
T.J.'s88GT
Bois D'Arc MO.
Jun 7, 2006
  • Jun 7, 2006
have already done a complete tune up still has the miss. changed coil, fuel filter, etc... the only thing that I've have found that's weird is when you unplug the o2 sensors it does'nt change anything? does'nt ever give a check engine light, so ???
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 7, 2006
  • Jun 7, 2006
that does seem wierd. Can you try pulling the codes from your car to see what it says is up.
T
T.J.'s88GT
Bois D'Arc MO.
Jun 7, 2006
  • Jun 7, 2006
I don't know how much you know about the eec5 but it sucks for getting it to give you a code!!! I've had this car for almost 10 years and have built 3 differant motors for it and this is the first time I've had any problems with a miss that was'nt mechanical?
HISSIN50
34
129
Jun 7, 2006
  • Jun 7, 2006
Um, an '88 stang is EEC-IV, and if it came SD from the factory, it doesnt have a functional CEL.
The car will run fine (FMEM) with no lambda input.
WHen pulling codes, run a cylinder balance test to see if the puter can pick up the miss (via an RPM drop, which is hard to detect by ear).
Good luck.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
