  • SN95 4.6L Mustang Tech
Prochamber is the devil
  • Thread starter Thread starter StangYellow
  • Start date Start date Apr 5, 2004
StangYellow
1,052
Apr 5, 2004
  • Apr 5, 2004
My car is back on the road and the gasket needs to be replaced AGAIN. Ive gone through 2 mac gaskets, 3 ford gaskets, and its still leaking. I want to know if adding mac shorty headers, or any other brands will help seal up the prochamber. What about adding 2 mac gaskets, has anyone tried that? Ive retorqued the bolts as suggested and within a month or so, the leak will occur and the mac gaskets literally blow up. Instead of buying a new pipe, id rather fix the problem. Oh, i also replaced the manifold studs on the drivers side to fix that leak, will this help the leak on the passengers side if i replace those studs too? Any information will be helpful, ive tried just about everything. Thanks.
kirkyg
3,568
Beaumont, TX
Apr 5, 2004
  • Apr 5, 2004
Man i dont know. I've never heard of anyone having problems with the stock gasket on the prochamber passenger side. The only problem there, is its a PITA to get to the bolts to loosen them up for the install. I never had an exhaust leak on the passenger side. Only had a leak on the driver side because of the shoulder on the bolt not letting me seal the flange down on the joint.
Why not try to get a stock ford gasket and apply it to the exhaust manifold. I never even pulled my stock one off and have never had a leak from it.
kirkyg
J
Jizzeff
93
  • Apr 5, 2004
Don't use the ****ty MAC gasket. Go out and buy a OEM Ford gasket or even use the one that you took off for the passager side manafold.
I also swaped the manafold studs on the Driver side.
Never had a leak here.
Its a good Pipe, Mac just has a ****ty gasket.
Take out that CRAP gasket and use the Original on the Passanger side
PROBLEM SOLVED
StangYellow
1,052
Apr 5, 2004
  • Apr 5, 2004
Yeah.... i did that with the ford gasket. Im about to replace the 3rd ford one. I know its leaking because i can hear the ticking sound inside the car. I was told the ford gasket was better, but the MAC sealed up better. The ford gasket can be bought 4 minutes away at the dealer
D
DCBigpimpin
130
TN
Apr 5, 2004
  • Apr 5, 2004
kirkyg
Yeah what he said. I had the same exact situation with my install. The driver side bolts needed to be replaced. After that no probs . The sound is
M
Mac-man
300
south texas
Apr 5, 2004
  • Apr 5, 2004
i had that problem too, but only with the mac h-pipe. what i did was went to the local hardware store and bought a fel-pro hasket made out of metal fibers. it looks like the mac gasket except it is thinner. i have had no problem with this gasket, and have actually reused it when i got my x-pipe.
JonJon
4,801
back in Marylands
Apr 5, 2004
  • Apr 5, 2004
lol that title is awesome
i'm gonna send this link to dk, he says magnaflow/bassani are CRAP quality and Mac is awesome quality
oogtdude
Banned
Jun 9, 2002
1,626
  • Apr 5, 2004
i put a prochamber on my 00gt teamed up with packs...the fitment sucked..it leaked and it sounded like ass wit my packs...was removed 10min later and sold here on stangnet..
mac=crap
kirkyg
3,568
Beaumont, TX
Apr 5, 2004
  • Apr 5, 2004
mac=crap
It leaked because you didn't get the NAPA stud kit to replace the bolts. If you had you would have been able to enjoy about the most beautiful sound ever.
kirkyg
slow87GT
162
Tonawanda NY
Apr 5, 2004
#10
  • Apr 5, 2004
  • #10
mine looked like it needed to be welded and ground to really be " inside the window"
it leaked at first, I did all the bs on drivers side from the get go, I just loosened the bolts and snugged them again w/3/8 impact gun, but I think the problem may slightly be having the nuts tightened evenly on the passenger side
StangYellow
1,052
Apr 5, 2004
#11
  • Apr 5, 2004
  • #11
I just found out today that MAC supposedly sells a new copper gasket for the prochamber. Im gonna try one of those when i get around to ordering it. Ill post my results once its on.
I also heard that MAC exhaust parts seal up well to other mac products, but doesnt seal up well with some others. Im thinking of buying the MAC shorties just so i dont have to hear that leak anymore.
dkshadow
Banned
May 12, 2003
952
TEXAS
Apr 5, 2004
#12
  • Apr 5, 2004
  • #12
I said they sound like crap... Never said they were crap quality. Macs quality isnt the greatest but the sound is
PG98GT
687
Mt. Carmel, TN
Apr 5, 2004
#13
  • Apr 5, 2004
  • #13
I didn't even try to seal the passenger side before I swapped to the NAPA studs. I'm still using the original stock gasket on the passenger side too. Swap out those stock bolts with the shoulder, use a stock gasket and you shouldn't have another problem with leaks.
M
Makalani_96GT
159
SoCal
Apr 6, 2004
#14
  • Apr 6, 2004
  • #14
MAC doesn't make a shorty header for the 4.6 do they?
DaDDyGSp0T
247
Southern Cali
Apr 6, 2004
#15
  • Apr 6, 2004
  • #15
you get what u pay for
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
  • Gulftown980x
  • Jul 29, 2026
squeak93
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
Need help 94 GT convertible top leaking
  • Scott94gtvert
  • Aug 9, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 9, 2025
General karthief
