  • SN95 4.6L Mustang Tech
Prochamber?
  • Thread starter Thread starter menasci
  • Start date Start date Feb 17, 2004
menasci
640
Chandler, AZ
Feb 17, 2004
  • Feb 17, 2004
What do you guys think of the Mac Prochamber?
I've heard some clips and really like it.
I have an American Thunder C/B with Stock H-Pipe.
-What will the difference in the sound be?
-Performance?
-Will the drone increase or decrease?
ASilver2001GT
636
Huntsville/Birmingham, AL
Feb 17, 2004
  • Feb 17, 2004
Dr. Gas X is the next mod for me
menasci
640
Chandler, AZ
Feb 17, 2004
  • Feb 17, 2004
I already did that.
Drone was horrible (even with cats).
ASilver2001GT
636
Feb 17, 2004
  • Feb 17, 2004
Well, if you don't like that one, I doubt you'll like the prochamber.
menasci
640
Chandler, AZ
Feb 17, 2004
  • Feb 17, 2004
What then?
daver01
396
Lexington, Ky
Feb 17, 2004
  • Feb 17, 2004
love mine, it did make my drone a little worse. so if you are drone-squeamish, i would steer away from it.
prochamber
R
RacerGT
2,371
St. Charles, Missouri
Feb 17, 2004
  • Feb 17, 2004
http://www.racergt.com/modulardepot/racergt/stopsign.AVI
http://www.racergt.com/modulardepot/racergt/wheelspin.AVI
Hard to hear, but I've got a prochamber and flowmasters.
R
RacerGT
2,371
Feb 17, 2004
  • Feb 17, 2004
Added another one... you can hear it better from this one.
http://www.racergt.com/modulardepot/racergt/prochamber.AVI
02mingreyGT
280
Portales, NM
Feb 17, 2004
  • Feb 17, 2004
Dude with ur flowmasters u will absolutley LOVE the sound and power it creates!! Im not so sure about the drone because i like it but i kno i dont experience it much. buy one now rpmoutlet.com CHEAP!
menasci
640
Chandler, AZ
Feb 18, 2004
#10
  • Feb 18, 2004
  • #10
Those clips are pretty nice.
Is it just me or does that exhaust setup sounds pretty tame from the inside of the car.
How much does it drone for you?
What are the differences from a stock H-Pipe?
R
RacerGT
2,371
Feb 18, 2004
#11
  • Feb 18, 2004
  • #11
It's relatively loud on the inside of my car. I have turndowns as well, aka no tailpipes. The camera I was using just doesn't pick up sound very well. It drones quite a bit between 1100-1900rpms but I'm never in that zone with my 4.10s so it doesn't really bother me. Major differences over the stock H pipe. Much more power.
menasci
640
Chandler, AZ
Feb 18, 2004
#12
  • Feb 18, 2004
  • #12
I've got 4.10's too.
So the Prochamber makes the drone appear in lower RPM's than
the stock pipe?
If so, that should be OK.
I'm looking to make my Flows "growl' more.
T
tripsober
217
massachusetts
Feb 18, 2004
#13
  • Feb 18, 2004
  • #13
yout SES light is on hehe
R
RacerGT
2,371
Feb 18, 2004
#14
  • Feb 18, 2004
  • #14
Yup, broke my front 02 sensor wire while removing my A/F gauge... oops.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 18, 2004
#15
  • Feb 18, 2004
  • #15
Go with the Prochamber
stangman
2,690
10
69
in a 3 bed, 2 bath
Feb 18, 2004
#16
  • Feb 18, 2004
  • #16
i love the prochamber. this is my second one it just got put on,s o i haven't got to fire it up yet. as far as power, i'll let you know in a couple of hours as soon as we get the k-member back in, it's off to the dyno. granted the dyno will be with longtubes too, but it will give you a idea
PG98GT
687
Mt. Carmel, TN
Feb 18, 2004
#17
  • Feb 18, 2004
  • #17
I have a ProChamber, and at first the drone was worse than I liked. If the drone really annoys you, put some sound dampening material on, like I did. The drone is still there, but significantly less and there are lots of benefits to using sound dampening. Suddenly, you'll hear your stereo better, road noise is alot less... Sometimes I do actually enjoy the stereo over the V-8 rumble, but only sometimes. There is a slight weight gain with adding the material, but it's insignificant. Just a thought. I am really happy with my ProChamber, having had it on more than 5 years now. The rust problems you may hear about shouldn't be a factor if you take normal care of it, especially considering where you live. I've lived in the midwestand eastern mountains where they use plenty of salt and other snow melting chemicals and with normal care, the pipes won't rust. Of course I only drive it when I have to in the winter. You may also get fooled initially by a loud "rushing" noise that will sound like a leak after you've had it checked out and find no leak, get used to it. As you have stock exhaust manifolds, you may need to change the studs on the passenger side from the stock ones (with an unthreaded shoulder) to full threaded studs. It's not really hard to do, if you don't, the ProChamber may not seal up fully and it will leak. Make sure you use the stock gasket, preferably buy a new one from ford. The one you'll get from MAC isn't as good and may give you trouble sooner or later. The drivers side is a ball and socket joint and won't trouble you. Make sure you have long extensions and a couple of swivels (and patience) to get to the manifold bolts.
F
fastang96
91
Gate City VA
Feb 18, 2004
#18
  • Feb 18, 2004
  • #18
I've had two prochambers. One was on with my stock manifolds and I just put another one on with the LT's. I have the old one for sale in the classifieds if you are interested. There is a drone but the sound is sweet.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
