[Project Car] 1986 5.0 V8 Foxbody Mustang Starting Issue
buckingpony
United States
So I've been working on a project car of mine which is a 1986 GT 5.0 V8 Foxbody Mustang. The car has sat for a very long time (~10 years) but within those 10 years, a few things have been changed and I managed to get it to start. It sat again for about a year, maybe two, before I finally decided to tackle this project head-on. Went to start the car and absolutely nothing. I replaced the starter and it sprang back to life (with some trouble) but the car then had a bad overheating issue. FINALLY, after putting basically an entirely new cooling system in the car (thermostat, water pump, hoses, clutch fan, and radiator) the car NO LONGER OVERHEATS!!!!!
I'm still having trouble starting the car though. First and foremost, the car cranks and will sound like it turns on but when I let go of the ignition it dies immediately. Sometimes it will actually die (read 0 RPM) and then start up on its own with like a 1-3 second delay. Otherwise, it will only start if I pump the throttle, sometimes I have to almost floor the throttle to get it to start (RPM will hit 5000 when it starts). I have also noticed when doing maintenance that the more I start the car, the easier it is to start; furthermore, when I do get it to start the car idles perfectly fine and can even drive. I tested the car battery the other day when the car was off and it read 12.1 Volts. I still managed to get it to start and took it on a good drive to test out the new cooling system. During the drive, the car kept randomly dying or would die when I would mess up switching gears. I kept driving and testing the battery voltage whenever the car would die and it kept getting lower and lower going from 11.7 down to 11.2. Eventually, when I got back to my neighborhood the car died completely and would no longer even crank.
One last weird thing that I've noticed that has happened to me so many times that I no longer think it is just coincidence is that when I do get the car to start, I'll get out of the car for whatever reason and it seems that the act of getting out of the car actually causes it to die. Like the rocking motion when I use my body's momentum to get out. I don't know if this has just been COMPLETE chance that the car happens to die the moment I try to get out multiple times or that there may be something to this.
I think I may have a bad alternator as my battery doesn't seem to be getting charged. I know for a fact that the battery was good as I just recently replaced it along with the starter and solenoid. The alternator is the only thing I haven't replaced yet. Does this seem like symptoms of a bad alternator?
My next plan of action is to get a new battery (still under warranty) and remove the alternator and get it load tested to see if it's still functioning correctly. Besides that, I'm also going to look at the wires and voltage regulator for any visible damage. Any tips/suggestions are appreciated!
General karthief
Mod Dude
Aug 25, 2016
23,999
8,882
203
polk county florida
Your car is possessed, or possibly just lonely from you ignoring it for so long, it senses you getting out and it's like 'oh no you don't! Get back in here!'
To exercise the demons go to the technical/how to forum here:
Down at the bottom you will find the 'surging idle checklist' and the 'cranks ok but no start checklist', start with the 'no start' checklist, it covers the things that you encounter when a vehicle sits, neglected and just generally unloved for long periods of time.
Or you can just send me a iTunes gift card loaded with money and I can fix it over the phone. I have POWERS.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,513
2,854
234
77
Dublin GA
lowendmac.com
The answer is in the note below... Read carefully...
It’s Decision Tree time:
No spark = go to step #1 & 2.
Good spark - what is a good spark can be a subjective judgment. If you have any doubts, borrow a known good coil from another pre 1996 Ford.
If you do have good spark = go to step # 3
Engine fires off and then dies = go to step # 4
Make sure that you have fuel pressure when the engine fires off. Leave the fuel pressure gauge connected while testing so that you can observe what the fuel pressure is doing.
Fuel pressure OK while cranking
Go to step # 5
Be sure to use a noid light to see if the injectors are pulsing. Use the most accessible fuel injector connector for the noid test.
Noid light pulses and fuel pressure is good.
Go to step #6
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachments\68357
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
attachments\610738
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Willybill32
But at least it's tight!
Jul 16, 2019
425
199
53
Lexington, KY
I, too, had an ‘86 that sat 10-15 years without running. First order of business was to drop the tank to check condition of it and the fuel pump. Did you do that? Mine got a new tank and fuel pump, along with cleaning the lines, and no run problems when I got to that point.
Reactions: 1 user
Sanstang
San Diego, CA
The fact that the act of exiting the car triggers the cut off of the engine suggests something may be obstructing the fuel pump in the tank, possibly your fuel filter sock has fallen apart and sediment sloshes into the inlet when you exit.
Reactions: 1 user
buckingpony
United States
I haven't checked the tank but I have replaced the starter and fuel pump! I haven't got a chance to change the alternator yet as I've been busy with other things but I will update soon!
buckingpony
United States
So I took off my alternator and took it to the parts store, it failed completely and the test was run at 65 Amps. Went and got a new battery and put in both the new battery and the new alternator and everything seemed to be working fine. Car started immediately BUT it did the thing again where as I tried to get out of the car it died. Started it two more times after this with no trouble.
Come this morning I went out to start it up and the car just kept cranking. After a few times of trying I let the fuel pump prime for about 20 seconds and then I tried to start it and it worked. I think you're right about it being a fuel problem. My brother recently changed the fuel filter so it should be fine. I'll double check with him to make sure he put it on right. If it's not the fuel filter, what should I do next?
Mustang5L5
Put lubricant all over the balls
Mod Dude
Feb 18, 2001
39,700
15,485
224
Massachusetts
If this was my car, I would get a fuel pressure gauge on the rail to monitor pressure, and dump the codes to see if the ECU isn't liking anything. Fuel pressure could be one cause, but there are sensors that can also cause your symptoms such as a bad ECT sensor (which floods out the engine, flooring the gas pedal will turn off the injector pulses allowing it to clear and start).
Go back to the basics. Air, fuel, spark and dump the codes. I'd hold off on compression testing unless you suspect the car could have a blown HG (it was overheating before, but that could be due to poor cooling system parts)
