Projector headlights?
Torinalth said:
why would you lose the high beams?
T
You don't lose the high beams...the outer lamps are your normal driving lights and the inner ones are your high beams...I can understand why the HID bulbs will not work...you don't plug directly into the bulb as you do now with the factory lamps, you plug into a pigtail that comes out the back of the housing...the bulb is well sealed in the unit and there is some special wiring configuration you can see when you open up the back of the housing
here is a pic of them....some have the clear projector lens and some have the blue/purple lens...I think the purple lens has not been release as of yet...still a few more weeks.
http://www.cruizinconcepts.com
