  • SN95 4.6L Mustang Tech
Proper jacking procedure
  • Thread starter Thread starter MachOut
  • Start date Start date Mar 20, 2004
M
MachOut
97
  • Mar 20, 2004
I've been working on cars for a couple years.. Nothing huge.. Switch out catbacks and springs.. Things of that nature. Always did things on my own. My friends are not car guys.. So this may sound like a dumb question, but what is the best way to get a Mustang on 4 jack stands?
Reason I ask, getting an Xpipe and want to get the car up off the ground without damaging anything.. I mean, I can jack each side up and put the stands under, but it seems like the body is absorbing a lot of flex..
stangman
2,690
10
69
in a 3 bed, 2 bath
Mar 20, 2004
  • Mar 20, 2004
you are leaving yourself sooooooooo wide open with that title
but on topic, why not just jack up the front end instead of trying to get the whole car in the air it's very doable that way
M
MachOut
97
  • Mar 20, 2004
I know man, I just re-read that title.. At this hour on a Friday night, I'm asking for it..
But back on topic... Ramps would provide enough clearance to get the Xpipe on?
dkshadow
Banned
May 12, 2003
952
TEXAS
Mar 20, 2004
  • Mar 20, 2004
http://www.bullittarchive.com/Maintenance/jacking
That should help
R
rob1
94
Indiana
Mar 20, 2004
  • Mar 20, 2004
Aaron 4.6
2,695
Georgia
Mar 20, 2004
  • Mar 20, 2004
1 jackstand under each front control arm (jack the car from the middle of the K member)
1 jackstand under each rear axle tube (jack the car from the differential.)
M
MachOut
97
  • Mar 20, 2004
I heard you shouldn't jack the car from the differental.. But I've done it before as well.. Just wanted to see if there was a better way to get the car into the air...
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Mar 20, 2004
  • Mar 20, 2004
not by pumpkin, but just befor that, there is big steel thingy you can jack backend with
BlkDragon
162
St. Louis
Mar 20, 2004
  • Mar 20, 2004
I just did my x-pipe. Don't bother jacking the whole car up, just jack the front as high as it will go and use 2 jackstands. It'll be tight but manageable.
stallion98gt
1,802
Los Angeles, CA
Mar 20, 2004
#10
  • Mar 20, 2004
  • #10
how do u like ur exhaust setup ?..I have the same and I love it !!!!
neoclasiccl
3,043
Help I can't see !!!!!!
Mar 20, 2004
#11
  • Mar 20, 2004
  • #11
My cobra is low and Ramps worked for both the catback and the xpipe install.
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
