Proper oil pressure
  • Thread starter Thread starter Rapid
  • Start date Start date Jan 4, 2007
R
Rapid
297
Columbia, SC
Jan 4, 2007
  • Jan 4, 2007
Just installed guages. I hae 75 lbs oil pressure at cold idle. 50 Hot. Too much?
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jan 4, 2007
  • Jan 4, 2007
That is pretty high. What's the pressure at ~2000-300rpm hot? What weight of oil?
R
Rapid
297
Columbia, SC
Jan 4, 2007
  • Jan 4, 2007
I'm running 10w-40 the oil pressure does not seem to go over 80. I have a Mullings HD pump.
rbohm
6,698
550
204
tucson,az
Jan 4, 2007
  • Jan 4, 2007
the basic rule of thumb is 10psi per 1000 rpm, with a minimum of 15psi at idle hot. 50psi at idle is too high.
C
corys69mach
  • Jan 4, 2007
I run about the same oil pressure with my 351c. Just have stock oil pump. No problems. Seems just fine.
R
Rapid
297
Columbia, SC
Jan 5, 2007
  • Jan 5, 2007
I tried a different search and came up wit oil filter information. Some have more restriction than others according to the thread. I am going to try a different filter then a lower weight oil just to see if there is a difference. I like plenty of pressure but dont want to hurt the distrbutor shaft or any thing else.
Thanks.
67Dylan
259
Phoenix, AZ
Jan 5, 2007
  • Jan 5, 2007
I'm betting you have a Mellings HP pump and not what is quoted. Do you have the p/n for the pump? If it is a HP pump that will explain the pressure. Changing oil weight/filter will have a little effect, but won't help w/as much pressure as you are running IMO.
Either way, it is too much pressure, as was stated by rbohm, 10psi per 1000rpm is the general rule of thumb. Too much pressure is only going to hurt the internals... unless you have the need for a HV pump?!
rsev216
109
Pinetop, Az
Jan 5, 2007
  • Jan 5, 2007
I run Mobil 1, 10w30 in my 65 289. It's has always been 80 at cold idle. It drops to around 35 at hot idle and 50-60 at 3000 rpm. That is typical for the 289.
R
Rapid
297
Columbia, SC
Jan 5, 2007
  • Jan 5, 2007
No,
I do not need that much pump. I'll try to dig up th PN for the pump but it has been in for about a year now. I try to keep paperwork.
Thanks guys. I'll get back to you when I ID the pump.
G
grego37
576
Fresno CA
Jan 5, 2007
#10
  • Jan 5, 2007
  • #10
if you were to add a remote oil filter and/ or oil cooler and remote lines , your pressure will drop some
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
SN95 V6 Mustang Tech May 22, 2026
PNN
P
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
