pulled code 1451
  • Thread starter Thread starter 35thstang99
  • Start date Start date Nov 12, 2008
35thstang99
77
  • Nov 12, 2008
what does this mean P1451 Lack of Response From Passive Anti-Theft System Module - Engine Disabled?
hotcobra03
poteet,tx
Nov 12, 2008
  • Nov 12, 2008
Hate those testers.they can tell half why not the other half?1451?thats evap .1260 is pats
35thstang99
77
  • Nov 12, 2008
1260 is theft detected engine disabled...1451 is passive system..
http://forums.stangnet.com/421143-ford-obdii-codes.html
hotcobra03
poteet,tx
Nov 12, 2008
  • Nov 12, 2008
Im on a cell and could only get 2 1364.google it its a typo that also shows 1260.my guess is somebody did a massive burnout! Look behind left rear solenoid on canister. Un plug clean and try again any other codes?
35thstang99
77
  • Nov 12, 2008
no massive burn out ...maybe it is a typo ill have to put it on the ford scanner tomorrow and see i pulled the codes with my hand held tuner...other codes are just for the oxygen sensors...thanks for the help ill let you know what happenes tomorrow
hotcobra03
poteet,tx
Nov 12, 2008
  • Nov 12, 2008
An o2 code is a must to fix
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Nov 12, 2008
  • Nov 12, 2008
1451 is an evap code. replace the canister vent solonoid and flow valve
hotcobra03
poteet,tx
Nov 12, 2008
  • Nov 12, 2008
Yea what said its located behind left rear wheel
35thstang99
77
  • Nov 14, 2008
figured it out blown fuse which is for evap and o2 heaters..changed fuse and is fine now ill have to drive around sunday once the weather is clear and see if the codes come back but thats what the fuse was for those codes or circuit
hotcobra03
poteet,tx
Nov 14, 2008
#10
  • Nov 14, 2008
  • #10
What fuse did u change?
35thstang99
77
#11
  • Nov 14, 2008
  • #11
it was for the the o2 heater and evap circuit it was a 20 amp my friend works at ford and i called him and he looked in the book and he said yes that fuse is for those circuits
hotcobra03
poteet,tx
Nov 14, 2008
#12
  • Nov 14, 2008
  • #12
Thanks ill note that .you said you had other codes.i like to search those.when doing test some codes must be fixed 1st.i use fords books and their are so many footnotes.thanks for sharing and responce back
35thstang99
77
#13
  • Nov 15, 2008
  • #13
yea the other codes were linked to that fuse through the circuit so there alll fixed
hotcobra03
poteet,tx
Nov 15, 2008
#14
  • Nov 15, 2008
  • #14
Thats what im looking for . the tie in .all of your codes is what i need just codes.thanks
35thstang99
77
#15
  • Nov 15, 2008
  • #15
these were all the codes...0443,1451,0135,0155
hotcobra03
poteet,tx
Nov 15, 2008
#16
  • Nov 15, 2008
  • #16
Thanks
hotcobra03
poteet,tx
Nov 15, 2008
#17
  • Nov 15, 2008
  • #17
I like to share my findings.your car should be ok.this is not ment to offened anyone.its not what class you sat through for your patch, its the end result .your problem should have been found in basic checks. Am i wrong with assuming most posts the person has done that already. Like this one .he asked 4 1 code with out telling all.i enjoy stangnet wish we had this 20yrs ago.maybe more detail and remember basic
35thstang99
77
#18
  • Nov 15, 2008
  • #18
just for your information i was just wondering what code that was i shouldnt havr to post my other codes to figure out what exactly 1451 was
hotcobra03
poteet,tx
Nov 16, 2008
#19
  • Nov 16, 2008
  • #19
Yes thats right.but like i said most post in tech we assume u have a problem.you were wrong on your discription.than you wanted to debate it also.your o2 code gave away the answer. Read other stories most go in circles.this isnt directed at you at all.get ur self a service oem book(cd) it has everthing in it.
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
1993 airbag module noise
  • Charlie1
  • Sep 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2025
Charlie1
C
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
