pulled codes 67 and 85 now what?
  • Thread starter Thread starter old_blue
  • Start date Start date Apr 29, 2006
old_blue
1,783
282
124
Apr 29, 2006
  • Apr 29, 2006
I am guessing that 67 is the nuetral safety switch?? what is 85? I have a 5 spd and not sure how to read that code. surges a little and it smells like it is burning rich. any ideas? thanks
HISSIN50
34
129
Apr 30, 2006
  • Apr 30, 2006
67 can be from having the A/C selector turned on, or not being in neutral.
85 has to do with EVAP. Check the charcoal cannister for leaks, as well as the purge line from the cannister to the intake. Mine happened to have vulcanized on both ends.
The vapors are purged into the intake while driving. But a leak can lead to a gas stink.
Good luck.
old_blue
1,783
282
124
Apr 30, 2006
  • Apr 30, 2006
do you think that is what the smell of being rich I am getting then? also, can there be codes for when the car is running ? I turned the car on with the jumper and it wanted to die so I just shut it off. Are there any tests that I could perform while the car is on to pull codes?
old_blue
1,783
282
124
Apr 30, 2006
  • Apr 30, 2006
also, if the canister is leaking what do I need to do ?
HISSIN50
34
129
Apr 30, 2006
  • Apr 30, 2006
Yes, you can run KOER (key on, engine running) codes if you can get the car to keep running. It's very worthwhile to do so.
An EVAP leak will basically vent gasoline vapors into the atomosphere (the system is closed by design) and can cause some decently strong fuel smells IMHO.
Just check things over first. The charcoal cannister is in the lower passenger side front fender (to the passenger side of the smog pump). You can see it from on top, but it's easier to examine the lines from underneath. It looks like a little bread box. Check the lines at the top of the cannister and look at the purge line at the intake. It runs under the front of the upper intake. You can feel the hose and note brittleness or cracks. That's how I found mine to be crappy. That line is a goofy one in that the line changes sizes in its run. I had to meld two pieces of hose (fuel and vac line IIRC) to make the connections (it was rotten at both ends - the cannister and the intake).
Good luck.
old_blue
1,783
282
124
Apr 30, 2006
  • Apr 30, 2006
well, I think you may have just told me where that extra vacuum line went to. I don't see a line going to the intake from the canister. Thanks hissin!
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Apr 30, 2006
  • Apr 30, 2006
85 Canister purge (CANP) circuit fault
An 88 with a EVAP pressure sensor in a 1988? I think someone is thinking OBDII here. That is a canister purge circuit failure, its probally the valve. You don't even need the canister there, it only detects the operation of the switch.
67 Neutral drive switch drive or accelerator on (engine off)
Check the tps Voltage and operation of the TPS, then be sure the Neutral switch which operates like a brake switch, isn't permenently on. It either detects the clutch is alway in or out, it's one or the other.
P
postalbunny
118
Apr 30, 2006
  • Apr 30, 2006
I get that 67 every time if i don't hold the clutch in while i run the test. I think it may be due to a bad aod/5speed swap (it is a 5 speed now). Or you may be required to hold the clutch in while the test is running.
old_blue
1,783
282
124
Apr 30, 2006
  • Apr 30, 2006
It is an 88 with an 89 motor and MAF. I don't even have the cannister hooked up to the intake at any point. Where is the valve located at?
The car originally had an automatic and I put in my drivetrain with the t-5 and kept the plug on the nuetral safety switch as I like not having to be in the car to start it. I think that is causing the 67 code.
I will check the canister but where is the valve that will throw that code? will it throw it even though it isn't hooked up? thanks Jon
old_blue
1,783
282
124
Apr 30, 2006
#10
  • Apr 30, 2006
  • #10
I need to get my voltmeter (just moved so it is somewhere in the garage.) What should it be reading?
P
postalbunny
118
Apr 30, 2006
#11
  • Apr 30, 2006
  • #11
I think its Green wire to pos and at rest you want as close to .99 as possible and full throttle should be 4.5
The cannister hooks up to a hose that I have to cramp my hand in the cubby hole under the upper intake to get to. I can barely push that bad boy on... it's the cubby behind the distributor i'm talkin 'bout.
old_blue
1,783
282
124
Apr 30, 2006
#12
  • Apr 30, 2006
  • #12
kewl thanks. It used to be a 4 cyl so the canister line for the intake goes to the back on the engine where I have that vacuum line behind the dizzy capped off because I didn't know where it went. Thanks everyone for the help. I will get that put on and see if it drops the code. Then I will try it running and see what happens.
HISSIN50
34
129
Apr 30, 2006
#13
  • Apr 30, 2006
  • #13
If you have done a MAF swap, check with the MAF conversion guys. I seem to recall issues after such a swap, with some of the things you noted.
Good luck.
old_blue
1,783
282
124
May 3, 2006
#14
  • May 3, 2006
  • #14
it shouldn't be an issue as I used all the 89 wiring besides under the dash. computer and all for under the hood. I believe that is all I need. Am I missing something else for this??
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
