  • SN95 4.6L Mustang Tech
pulled codes need help
  • Thread starter Thread starter mat82284
  • Start date Start date Sep 21, 2005
M
mat82284
889
  • Sep 21, 2005
I pulled my codes and this is what ive got. what do i need to do to fix them? also whats the fuel pump thing? and how do i fix the idle air control problem? i added a 70mm tb and c&l intake and have been having problems with the idle. i replaced the tps and have it set to .99v thats it low as i could get it and the tps is drilled to allow more movement. now it seems more it coming about
P1233-Fuel Pump Dvr Mod Disabled/Off Line
P1506-Idle Air Control Overspeed Error
sgarlic
3,085
Sep 21, 2005
  • Sep 21, 2005
Did you replace the fuel filter lately? That first code I usually see people complain about is from the emergency shutoff switch in the trunk being disconnected. Others have had the problem due to a clogged vent tube.
The second one sounds like it's definately related to the TB/plenum.. but hopefully somebody will chime in to help with that.
sgarlic
3,085
Sep 21, 2005
  • Sep 21, 2005
Oh, here's what the second code is:
This DTC is set when the PCM detects engine idle speed that is greater than the desired rpm.
Possible causes:
IAC circuit short to GND
Damaged IAC valve
IAC valve stuck open
Vacuum leaks
Failed EVAP system
Damaged PCM
Checks:
Disconnect IAC valve and look for little or no change in engine rpm as an indication of a stuck or damaged valve.
M
mat82284
889
  • Sep 21, 2005
ok when i remove the iac valve the blank hose connected to the intake and plenum right? well when i pull it off the idle drops a little but when it was on and i reved it it would stick a little at 1400 and when its off it doesnt stick
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Sep 21, 2005
  • Sep 21, 2005
my car actually threw the p1233 fuel pump code when I installed a raptor shiftlight (hooks in by the computer). the ses light is still on from this. no clue why it's doing that
M
mat82284
889
  • Sep 23, 2005
the car idles the same when the black iac box is disconnected whats causing this what do i need to do to fix my idle. i noticed its at 1600 now seems to be riseing. it only sits that high when im in nutral wile moving but when i hit a light and stop completely it stays at 1600 for 2 secs then drops to 1000 now a lil wile ago it was 800 now its 1000 what do i need to do to fix this?
M
mat82284
889
  • Sep 23, 2005
anyone?
sgarlic
3,085
Sep 23, 2005
  • Sep 23, 2005
Put your stock TB/plenum back on, and see if that fixes your idle problem. If it does, add the TB. Then try again, if it still works, then try the plenum, etc. This way you can narrow down the problem and work from there.
M
mat82284
889
  • Sep 27, 2005
Vacume Leaks Help
ok ever since i installed my tb /plenum ive had nothin but problems. first the tps was bad replaced and its set at .98 now and the car idles at 1600 when in nutrual wile moving but at a stop its 1000. ive reset the computer multiple times and nothing. i also unpluged the iac and pluged the whole and the car ran good idled at 900 and drove like normal. i was told that when you turn off the iac its supposed to die. mine doesnt is this because of a vacume leak?? how do i check for leaks? i also keep getting this code after a week of drivin. can i just drive with the iac unpluged or will it through codes?
sgarlic
3,085
Sep 27, 2005
#10
  • Sep 27, 2005
  • #10
Unplugging the IAC when the engine is warm/hot won't do anything.. it only serves a purpose when the engine is cold (sort of like a choke.)
You can check for vacuum leaks by spraying WD-40 or using a spray bottle with soapy water, and just spray it on all the hoses while watching for bubbles. If you see any, you've got a leak.
M
mat82284
889
#11
  • Sep 27, 2005
  • #11
thanks. is it ok to pray the soapy water on the intake to check for leaks too? i think maybe a gasket it bad on the tb or iac. or maybe the intake isnt tight enough. it all looked good just want to double check. so its ok to pray it there? im guessing just to keep the water away from the injectors.
M
mat82284
889
#12
  • Sep 28, 2005
  • #12
well i bought a new pcv and it still didnt fix it. its still idleing high and still throughing the same code. i guess i dont have a choice but to take it to a machanic.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
