Pulled KOEO codes,can someone help me deciphter them???
  • Thread starter Thread starter Foxfan88
  • Start date Start date Jun 18, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jun 18, 2005
  • Jun 18, 2005
Pulled KOEO codes,can someone help me decipher them???
67
81
82
85
I pulled them, can someone help me out???
My car has a aftermarket harness, its made by Painless if that makes any difference.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 18, 2005
  • Jun 18, 2005
67 = Clutch switch open, A/C left on, Transmission in gear
81 = TAD or AM-2(Thermactor Air Diverter)/Secondary Air Injection Bypass (AIRB) solenoid circuit failure
82 = Same as 81, but with the TAB (Thermactor Bypass), circuit failure
85 = CANP (Canister Purge) solenoid circuit failure
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jun 18, 2005
  • Jun 18, 2005
Umm i dont understand any of those, can anyone help me??
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 18, 2005
  • Jun 18, 2005
Well with 67, just make sure your car is in neutral and the A/C is off next time you dump your codes.
For the others, you may want to hear what jrichker has to say. He's the wizard when it comes to codes... hope he comes in for ya.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jun 18, 2005
  • Jun 18, 2005
ok i understand the car being in gear, since the shift cable is messed up...
but the ac wasnt on..... why did sense it was on??
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jun 18, 2005
  • Jun 18, 2005
Missing information.
Why did you read codes? What is the problem. What is the car doing?
67 is the one that may actually cause problems, the rest are emmisions related. If the cable is messed up, the trans is doing one thing while the shifter postion is doing another. The ECU does make changes when the shifter is in different positions.
HISSIN50
34
129
Jun 18, 2005
  • Jun 18, 2005
Agreed with the 67. Next time take the car out of gear and that code will go away.
As said, read Jrichker's old posts for the smog pump info.
The Charcoal cannister purge valve might not be working. That is not a huge deal, IMHO (of course, it should be repaired immediately ).
good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 19, 2005
  • Jun 19, 2005
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
See http://www.veryuseful.com/mustang/t...ng5.0Vacuum.gif for help on the vacuum line plumbing.
Code 82 – Secondary Air Injection Diverter Solenoid failure AM1. The dump valve air diverter valve (front vacuum operated valve) isn’t working on the Thermactor Air System (smog pump). Look for broken or missing vacuum lines on the solenoid valve to the diverter valve Check the solenoid valve for +12 volts at the Red wire and look for the Red/White wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the Red/White wire for the solenoid valve
Code 85 - CANP solenoid - The Carbon Canister solenoid is inoperative. Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
P
CEL light on and Can't pull KOER codes.
  • psfoxstang
  • May 7, 2024
Fox 5.0 Mustang Tech Jun 20, 2024
psfoxstang
P
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
