  • SN95 4.6L Mustang Tech
pulled some codes today
  • Thread starter Thread starter 98laseredgt
  • Start date Start date Mar 30, 2005
9
98laseredgt
122
indianapolis
Mar 30, 2005
  • Mar 30, 2005
i got:
lean on both banks P0171 and P0174
o2 heater circuit malf. bank 1 sensor 1 P0135
low fuel pressure (cleared yesterday, did not come back today. but now has lean codes)
DPFE EGR circuit low imput P1400
so, im thinking i need a fuel pump, o2 sensors, and anyone got any ideas on the EGR? my gasket that goes from the EGR tube to the intake plenum is messed up. ill probably replace that and see if that works.
on the fuel pump, i have a 98 and im not sure if its got the return or returnless fuel system. i do have 2 lines off the passenger side fuel rail, does that mean its return style?
thanks for the replies.
nate
jstreet0204
939
Winston Salem, NC
Mar 31, 2005
  • Mar 31, 2005
98 is return style. I'd just replace the fuel pump first. The other codes may be caused by the lean condition and my go away after you fix it.
T
TGJ
1,049
  • Mar 31, 2005
I am going to suggest something.
P0171, P0172, P0174, P0175 can be caused by a dirty or messed up MAF. I would clean the MAF as well.
To clean the MAF, you need a Torx T-20 tamper proof screw driver to remove the 2 screws. Take out the MAF electronics, spray with Electrical Contact Cleaner and if need be use a Q-Tip on the wires. Be extremely careful if you use the Q-tip.
9
98laseredgt
122
indianapolis
Mar 31, 2005
  • Mar 31, 2005
thanks, i just cleaned the MAF when i put the C&L on, but it has a greasy K&N on it so ill try it again.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 31, 2005
  • Mar 31, 2005
for the EGR code you need a DPFE sensor.. common if it was a low flow code i would put a vac pump on the vac nipple on the egr and at idle pump some vacum too the egr.. it should stall the car... if it does then it's the dpfe... if not the egr ports are clogged...
as far as the the engine codes.. . for the lean codes i would put a fuel presure gauge on it and if your readings are normal then i would look at the maf or a poss. vac leak..
9
98laseredgt
122
indianapolis
Mar 31, 2005
  • Mar 31, 2005
ill check that stuff out also. i just order a fuel pump so hopefully that will help.
Mike97gt
it doe snot
10,633
Mar 31, 2005
  • Mar 31, 2005
you should check the fuel pressure first.. pump may be fine...
9
98laseredgt
122
indianapolis
Mar 31, 2005
  • Mar 31, 2005
im getting the pump for a different reason, just need to figure out if i want wet or dry...
i used to own a Z28 also. 95' M6
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
