Pullies and a/c delete kit?
  • Thread starter Thread starter mustangfiveo198
  • Start date Start date Dec 22, 2003
mustangfiveo198
145
Driving my STANG
Dec 22, 2003
  • Dec 22, 2003
I just bought a set of underdrive pullies and a a/c delete kit for my stang. My question is do I delete the a/c first before I put on the pulleys and will I need a new belt after I install the pullies? Also how hard is it to install and do I need any specila tools?
Thanks alot for all the help.
Black 93 Fox
1,995
Vancouver,Washington
Dec 22, 2003
  • Dec 22, 2003
You will need a new belt if you take the ac out also. I put under drive pulleys on my car and took my out 15mins. i also put on a smog pump delete which just puts a pulley there so i can use the stock belt. About the tools you will need a impact gun to get the nut off the alt. Also if there is a shim under the nut make sure you put that under the new pulley when you go to put that back on the alt if you dont you can screw up your alt.
How much did the a/c delete cost you?
strtracer442
175
Roseville,MI
Dec 22, 2003
  • Dec 22, 2003
You can do both at the same time, you will definitely need a new belt.
The only special tools you should need are a set of SpringClamp tools.
Any good auto parts house should have them, mine were less than 15.00, and they work on the fuel system too.
Make sure your ac system is evacuated before you start, freon is heavier than air, a very dangerous situation if you release it in an inclosed area. Dont just dump to atmosphere, its bad for the ozone.
strtracer442
175
Roseville,MI
Dec 22, 2003
  • Dec 22, 2003
A/C delete kits are $42-47 bucks throught summit and jegs.
I use the March kit(42.00) its lighter, uses fewer parts, and you dont have to touch the power steering
mustangfiveo198
145
Driving my STANG
Dec 22, 2003
  • Dec 22, 2003
Thanks for all the replies.
Is there a certain belt I need?
Black93, You said you did the smog pump too? Where do you live? I don't think I could do that here in CALI. the kit cost me 39.95$.
strracer, thanks alot. But how do I evacuate the a/c? You mean get all the freon out right? I will be doing it in my driveway. I will be getting the spring clamps soon too.
strtracer442
175
Roseville,MI
Dec 22, 2003
  • Dec 22, 2003
A A/C machine is needed to remove the Freon from the system, you cant legally vent the system yourself. It shouldn't cost much for a ac shop to suck it clean for you.
mustangfiveo198
145
Driving my STANG
Dec 22, 2003
  • Dec 22, 2003
I will be calling around for a A/C place now too................
9
92BlackGT
182
Tinker AFB, OK
Dec 22, 2003
  • Dec 22, 2003
the a/c place should take out your freon for free....because freon (R12) is gold to them, they sell that stuff for a lot of money.
If your system was converted to R134, you can evacuate the system yourself.
strtracer442
175
Roseville,MI
Dec 22, 2003
  • Dec 22, 2003
If your ac still works why do you want to get rid of it?
The ac system doesnt use any HP when its not in use, and it shuts itself off at WOT. The only problem is the weight it adds, but there are other ways to lose weight. Removing it will greatly deminish the re-sale value.
If it does work, and you still take it off, I would be interested in buying the components from you.
Strtracer@comcast.net
Black331Stang
1,485
Long Island, NY
Dec 22, 2003
#10
  • Dec 22, 2003
  • #10
blackfox...UGH i hate calling people by there username hah whats your name??..anyway diversified products has the FMS kit for like 35 bucks...its the cleanest/most factory looking kit. plus u wont have an idler pulley hanging there. i think u already have one for teh smog and u dont want too many hanging around if u can just get rid of it all together. he smog one isnt bad but an idlr pulley right up top just doesnt float my boat. ugly imo.
89LXNotch
89
Sanatoga, PA
Dec 22, 2003
#11
  • Dec 22, 2003
  • #11
I agree!! The FMS kit is way cleaner looking than anything else out there. That's because they are the actual factory parts for a non-A/C car. I powdercoated mine before I installed it, looks sweet!!
sleeper89
388
Toronto, Ontario
Dec 22, 2003
#12
  • Dec 22, 2003
  • #12
FWIW the 100% best way (IMHO) to delete the a/c is by getting the p/s bracket from a non a/c car and using the factory non-a/c size belt. this will move the p/s up to where the a/c is and no UGLY idler pulley. this is probably the cheapest way too.
....just my opinion though.
-steve
Black 93 Fox
1,995
Dec 22, 2003
#13
  • Dec 22, 2003
  • #13
Hey black331 my name is Andy.
Mustang5oh-I live in washington. My shop told me if i put my stock h pipe back on i will pass emmisions.
tvmango
667
bradenton florida
Dec 22, 2003
#14
  • Dec 22, 2003
  • #14
he's right , they should take it for free.......
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
  • dan50
  • Jul 18, 2026
dan50
