IMO i dont think it is... maybe 5-10hp increase... i did notice a slight difference when i got mine. but it wasint worth it to me... because of charging issues... and i had 3G Alt and still gave me crappy charging at idle! just not worth it in some cases... or you can do it and have no problems
I think underdrive pullies are probally one of the best bang for the buck mods out there. Usually they make between 7-12rwhp and TQ difference and a noticable SOTP difference.
i noticed mine, would bust the tires loose easier it seemed like. Recently i went back to the stock alt pulliy, was having some charging issues. Wont make really any difference with the alt pulley or not.
Yea im not the best speller I am just asking about the pulley's for when I get a stang because I would like to do under the hood mods and make it a sleeper sort of.
The only issue with under driven pulleys is when it’s time for certain S/C’s you can not use them anymore. So make sure you save your stock pulleys if you plan on going forced induction later on. Right now, I have BBK’s steel under drives and I noticed a nice SOTP gain. I don’t have changing issues but I run a 3G with an overdriven pulley to compensate for the slower belt speed.
the alt wouldn't make much difference if any they have little to no drag to them if your alt is hard to spin you should look into getting a new one. The only underdrives that I think would make the SOTP meter gain would be the crank and probly the water pump. The power steering is a bit harder to turn than the alt so it might help a bit as well. You can go to a wrecking yard and measure different pully's and find ones that would fit and get your own set for dirt cheap But they won't look as cool as a set of billet ones
