  • SN95 4.6L Mustang Tech
pulling car! grrrr
  • Thread starter Thread starter kid rock
  • Start date Start date May 11, 2006
kid rock
99
THE 51ST STATE!!
May 11, 2006
  • May 11, 2006
Hey boys and girls,
Right i have a 98 reg GT and since buying the car about 2 months ago it has recently started to pull to the left, so much so that i thought it might have been the tracking! so off i went ot the localgarage and got the tracking, balancing and my tires checked! now they are all spot on! BUT the car still pulls to the left!
What do you reckon it could be?
susspension sagging? ( or maybe the suspenson being to soft for our ****ty british roads??)
had the car off the ground and had a look underneath but everything looked fine!
Please help me guys
Si
P.S its not under braking so wont be a sticky pad/disc!
four six
506
Hobart, IN
May 11, 2006
  • May 11, 2006
you prob need an alignment thats what I needed
tomustang
Psychotic Member
3,434
McLean Hospital
May 11, 2006
  • May 11, 2006
Get an alignment, rule out the no brainer
C
cooter_11
138
GA
May 11, 2006
  • May 11, 2006
Before the alignment, I would swap the front tires to see if you have a radial pull. I may save you time and money.
Dorsai
Connecticut
May 11, 2006
  • May 11, 2006
+1 Agreed on the radial pull.
Don't count out a pad dragging with your foot off the brake...that's why it's called dragging...it drags all the time.
02FastblackGT
64
Tucson, AZ
May 11, 2006
  • May 11, 2006
What suspension do you have?? If your car is lowered, and you never got an alignment, then you deffinetley need one!! If you have stock suspension, then it might be time that your car needs one. My stang was barely pulling to the right after I did my suspension. I went and got it aligned shorlty thereafter, and now it is all good!! Good luck
kid rock
99
THE 51ST STATE!!
May 12, 2006
  • May 12, 2006
ok kool cheers guys, but urrr (time to sound thick) what is an allignment on my car? ie how do they do it and what do they change??
OR
is it the same as our "tracking" in which they check to make sure the wheels arent pointing togethor or away from each other etc etc
i also only have stock susspension!
and yes it could be a sticking disc/pad i suppose in that its always dragging!
if the g/f allows ill swap the tyres over at the weekend!
if not the car is going in for a service at an american car specialist over here in 2 weeks time!
could somthing be broken??
Si
loosescrew79
313
  • May 12, 2006
Good call on the radial pull.
Just switch the two front tires and see if it pulls the other way.
DTNODYA
831
  • May 12, 2006
I agree, also rule out another no brainer .... check your tire pressure. That will cause a car to pull big time.
BigChiefSmokem
1,400
Jacksonville, FL
May 12, 2006
#10
  • May 12, 2006
  • #10
You really dont know what an alignment is? Thats where they correct the camber/caster and toe of your wheels so your car doesnt pull right or left and for even tire wear....
http://www.familycar.com/Alignment.htm
Dont forget to tell them to change your headlight fluid while you have it in the shop and up on the alignment machine.
Progress Thread 2001 Bullitt #265 - Build Thread (LOTS OF PICS)
  • MineralMan
  • Oct 21, 2019
  • 2 3
15K
1996 - 2004 SN95 Mustang -General/Talk- Feb 7, 2026
gkomo
Excellent Hagerty Article About The "kings Of The Street"
  • FoxMustangLvr
  • Sep 21, 2017
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2017
NIKwoaC
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
Century 21 Raceway
  • CarMichael Angelo
  • Oct 8, 2016
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 9, 2016
95BlueStallion
N
Just Bought An 86' Gt *pics*
  • Nickster914
  • Jun 26, 2015
2K
Fox 5.0 Mustang Tech Jun 30, 2015
Nickster914
N
