  • 1994 - 1995 Specific Tech
Pulling Cats
  • Thread starter Thread starter 1995GTStang
  • Start date Start date May 19, 2009
1995GTStang
74
Washington State
May 19, 2009
  • May 19, 2009
I am looking at pulling the cats and just going with an x-pipe to the mufflers. Is this a difficult procedure? What do you do with the pipe that comes off the heads to the cats? Can you just cap it off?
Thanks
HISSIN50
34
129
May 19, 2009
  • May 19, 2009
Removing the stock H and swapping in an X pipe is pretty easy. If you havent done this kind of stuff before though, you might wanna have a wrenching buddy come do it with you. You might have exhaust bolts that are stuck, etc.
donkey_punch
565
northern****ingjersey
May 19, 2009
  • May 19, 2009
pb blaster, or any kind of penetrating oil, will be your best friend, along with long extensions and a wobble end. air tools if you have them.
with the smog tube, it's cut off in the area where it attaches to the mid pipe. a piece of i think coolant hose with clamps is used to connect the smog tube to the new mid pipe. i'm not sure what type of hose is used, but it has a thick wall to it, and of course is heat resistent. first thing that comes to mind is a small coolant hose.
HISSIN50
34
129
May 20, 2009
  • May 20, 2009
Silicone hose has worked for me.
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
L
Exhaust 95 gt pypes catted x pipe
  • Lx5.0fiend
  • Aug 22, 2025
1994 - 1995 Specific Tech Sep 18, 2025
revhead347
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
