Pulling Codes
  • Thread starter Thread starter Makdaddymac
  • Start date Start date Nov 3, 2008
M
Makdaddymac
323
orlando
Nov 3, 2008
  • Nov 3, 2008
hey all how do i pull codes off my 94, it has an obd-2 style port.
auto zone hooked it up and it said error i need a way to do this im having some running issues, its a little different when all the scanners say 96+ and my
88's scanner has an old style obd1 port
what are you guys using to do this? test light? paperclip? i know there is free way but i do want a scanner for my tool box
94GTCoupe
1,412
92
79
CA
Nov 3, 2008
  • Nov 3, 2008
the test port for the 94-95 GT is under the hood on the passanger side strut tower.our cars are OBD1.
i use the Innova #3145,it's just code reader though,not a scanner.
i think the test port for the 94-95 V6 mustangs use the test port under the dash on the drivers side.i THINK these are OBD2??? NOT SURE THOUGH.
M
Makdaddymac
323
orlando
Nov 3, 2008
  • Nov 3, 2008
right but i have an obd2 port under the dash......
was this just ford planning for the 96?
mhespenh
50
Charlotteville/Blacksburg, Virginia
Nov 4, 2008
  • Nov 4, 2008
I know OBD-II compliance wasn't required until '96, but I swear I read somewhere that our 94/95s were at least PARTIALLY OBD-II compliant (as in at least some of the codes/polling should work).
Can anyone confirm/deny this authoritatively?
EDIT: Okay, after some research I found this:
According to this site the following engine family for the 1994 Mustang is partially OBD-II compliant: RFM3.8V8G1EK
And for 1995: SFM3.828G1EK
I have no idea what that means, but the 3.8 leads me to think V6 engines only
source: http://www.obdii.com/connector.html
I haven't personally used this, but perhaps it could work for easily reading codes (without the counting flashes PITA)
http://store.autotoolexpress.com/obfoscto.html
HISSIN50
34
129
Nov 4, 2008
  • Nov 4, 2008
As properly noted, the V8 '94-95's are OBD-I and use the STC on the passenger side firewall.
The 94-95 V6 cars were OBD-II, hence our cars having both connectors. The OBD-II connector will not work on GT/Cobras.
Use the connector under the hood and expect to see 3 digit OBD-I codes.
mhespenh
50
Nov 4, 2008
  • Nov 4, 2008
From the same source I linked to above (note, Ford uses PWM for OBDII):
J1850 PWM--The connector should have metallic contacts in pins 2, 4, 5, 10, and 16.
If your vehicle has this style connector, but doesn't have these pins populated, you probably have a pre-OBDII vehicle. To add some confusion, even having the connector with the contacts shown above is not a guarantee of OBD II compliance. This style connector has been seen on some pre-1996 vehicles which were not OBD II compliant.
M
Makdaddymac
323
orlando
Nov 4, 2008
  • Nov 4, 2008
ok well it was dark out at autozone and i didnt even think about the under th hood, i figured i wasnt in my fox and i had a newer style car hehehe but oh well obdI =les o2 sensors!!!!= cheaper fix!!!
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
G
1995 Mustang GT- No PCM Communication, Runs Rich, Lacks power
  • gtrob
  • Aug 30, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 31, 2025
N
Complex changes need help
  • nomoremasks
  • Sep 15, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 15, 2025
nomoremasks
N
T
2008 GT Parasitic drain - sjb
  • turcotjs
  • Aug 1, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 1, 2025
turcotjs
T
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
