Pulling motor!!!! HELP
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Well, after trying to get a friend who has done it many times to help, he keep dodging me, so I will try to tackle it myself.
I've got the car in the garage, and the hood off. What should I start taking off first? I was gonna get the belt, fan shroud, and radiator out first, and then pull dizzy, upper intake, remove exhaust, and start taking the motor mounts loose.
I haven't even done this before, and I'm taking the laptop into the garage with the router to keep checking in.
Please help me, and feel free to chime in and say which parts first and what makes them easier.:SNSign: :SNSign: :SNSign: :hail2: :hail2:
Are you removing the tranny with the motor? Didn't specify Auto or 5 speed? How about the drive shaft. Tranny and bellhousing if 5 speed. Inspection plate for flywheel for auto and then the torque converter bolts.
The car is a 5-speed, and I was planing on just getting the the motor ready to pull tonight, but not pull it yet. I will prob. get the motor out by itself, but if space in the garge and ceiling will permet, I'll pull tranny out with the motor.
What should be the first things I take off? Was my first little list in the right direction?
you dont need to remove the intake or dizzy to pull the motor. first get the front end pulled apart ie: radiator, fan, belt like you mentioned. what i ussually do is take the PS pump off the motor and let it sit on the K member so you dont have to open the system. next get rid of the headers and motor mounts, then disonect all the wires and hoses that are left. bolt the chains to the heads via header bolt holes in opposite corners then begin to pull stopping every so often to check for things you forgot. if you have an auto dont forget to remove the cooler lines.
I'd reccomend that you find someone knowledgeable to help you along, If you try and pull this engine out by yourself, its good to have a helper that way he can assist you. You dont want to be undoing something you forgot with an engine dangling above your head, play it safe, find a friend to help you.
I'll get pics of the car in the morning, but the fan, shroud, rad, cap and wires are out. Half of the header bolts are out. For the other ones, I think I need a 3/8 flex joint socket to get them, or a better 3/8 wrench with a longer shank. (broke a craftsman)
I'm taking it slow, making sure I know how to put everything back together. I plan to have the headers off by the end of tomorrow after I go to the parts store. Then I'll pull all of the A/C lines out of the way, since the compressor is dry, and I want to take it off. I'm gonna try for the speedo cable and clutch cable as well. I'm just gonna try to get everything loose and then bring a mechanic friend over and get help pulling it out.
It isn't that hard, I pulled the motor and tranny out of mine a few months ago. It was the first time I had ever worked on a car besides changing the oil in my Toyota 4-Runner once before.
Just make sure you label all the wiring connections before you take the motor out.. I'm glad I did, it has been months since my engine has been in the bay, but atleast now I know what each and every connection is for by memory :D
Don't forget the oil level sender and the ground strap behind the drivers side head like I did :D
No the strength is there, but the prevous owner put the headers on and the bolt heads look like this O. So I'm having to be very careful, and they're not coming off. 14 are off, and 2 remain. I broke a 1/4" drive universal adapter, ooops. "hello sears, it broke were's my new one?"
It would be so much easier if I had the perfect tools, and a lift.
Wow. I'd be careful if you haven't done this before, it can be unsafe. Most of all, don't rush yourself. Make sure all the bolts are off the bellhousing first before pull. Remove both motor mount bolts (may need to apply heat), and all wiring. I would recommend labeling your wiring or you'll be in a huge mess when you go to put it back together. Good Luck
I've labeled the connectors that I'm not familiar with. For the most part, I know where the wires go. I'm still trying to get this facking header bolt out, one on each side left. All I have left to disconnect is the tranny, motor mounts and fuel lines. Everything else is ready.
Header bolts can be fun when they're rusted. Mostly when I pull a motor, I'm replacing exhaust, so I cut the crap out of everything to save time, but if you have a pretty X-pipe or H-pipe that you don't want to ruin. Don't forget you'll need that fuel line tool to disconnect the lines. Good luck!
Jason
well just another little trick i do sometimes if u dont have the disconnect tool for the fuel lines is unbolt the 4 8mm bolts that hold the rails to the intake and lay a towel or somthing over the fender and set them up there out of the way.
It sounds like you are making pretty good progress for your first go at it. :nice:
I would suggest spraying some WD-40 on the header bolts, it will help.
I pulled my motor today as well. Good times!
Things can get a little dicey when lifting the motor out by yourself. But I have done it before. Just go slow, DOUBLE check everything TWICE. It is nice to have some else there though, even if they only watch to make sure nothing catches.
I think I missed your reason for pulling the motor though :shrug:
jason
Soaking those rusted header bolts with PB Blaster may help. Some heat (torch) will probably be needed to get them out though. If not I have cut the heads off the bolts before and with the engine out of the car without the headers attached the bolts always came out easily with some vice grips and heat.
Props to you for tackling a project over your experience level. Pay close attention to everything and you will be fine.
Take lots of pictures at various stages of disassembly. If your engine is out for more than a few days those pics can really come in handy when you put it all back together.
