Hey everyone, here are the specs of whats currently there: 1994 GT HO block dead stock with addition of F303 cam and windage tray, Patriot heads, Victor Jr intake, long tubes, full MSD ignition, and a bunch of other little other stuff. This is a street car, and not a drag car. Anyway I became broke halfway through the first build and reused the stock rings and bearings with the new heads, well as you guys know thats a crap shoot. Well my luck 1,000 miles later oil rings are shot so it is coming back out. The cylinder walls still have the cross hatch pattern with no ridge so I wont be boring the cylinders or using a stroker kit. I will be ditching the hyperutectic stock 94 pistons and replacing them with used low mileage 1989 forged ones, and also treating to new rings and bottom end bearings. SO........Heres my current puzzler, I plan on boosting down the road (10 psi or less) either with a turbo setup or a roots style blower. (1) Which rings are best standard ? Gapless ? Cast ? Moly ? Which brand ? I was looking at Sealed Power. (2) Upgrade headgaskets and to stud kit now or wait until induction gets added later ? If so which gaskets are best ? I was looking at the MLS Felpro headgaskets ? (3) What are you guys using for intake gaskets and bolts when boosting? (4) Do I really need to have rods reconditioned if they are low mileage, look good and withinspec? (5) I see MM&ff using stock rod bolts and main bolts with they're stock 5.0 turbo setups. This works but does it last? ........
..............As of right now Im planning on rings, bearings and a run of the mill engine gasket set and redoing the upper end when forced induction is added. Maybe this is more of a rant and a long one at that, just throw some input this way. Thanks
