pulling my 302...
  • Thread starter Thread starter 1WildII
  • Start date Start date May 25, 2004
1WildII
199
Anacortes, Wa
May 25, 2004
  • May 25, 2004
How do you guys hook up the chains to pull the motor? I was thinking about the plate that goes in place of the carb, but I was told that I shouldn't do that with an aluminum intake. Any other suggestions. BTW I have new chrome valve covers that I need to be carefull around. Any help would be awsome. Thanks in advance,
Chris
C
COBRAIIW
562
CT
May 25, 2004
  • May 25, 2004
any time i pull a motor,i put long bolts where the headers bolt on.this is where i hook up four equal length chains,two in front,two in back,and run all four to the hoist hook.
H
HaveII
272
Houston, TX
May 25, 2004
  • May 25, 2004
I have alway used one of the bolt holes in the heads where the accessories bolt on. then go across the motor and use one of the similar holes on the back of the other head. This keeps the chain from crushing the valve covers. This also give you lots of room to change the center position on the chanin to allow the motor to tip at an angle.
L
LedZ 5.0
now you have my pea brain going in circles
Apr 1, 2004
204
  • May 25, 2004
You can also pick up a few engine hook brackets at a salvage yard from some of the imports or Escorts. Just bolt them where you want and hook your chains or hooks up to them. It makes the work a lot easier.
LedZ 5.0
1WildII
199
Anacortes, Wa
May 25, 2004
  • May 25, 2004
Cool guys thanks for the input. Ill see what will work best.
Chris
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
Motor ID
  • 65er
  • Mar 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 14, 2026
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
H
Brand New Built 302 overheating
  • hassler
  • Sep 26, 2025
Rcdgl
R
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
