Push button start
  • Thread starter Thread starter 89five.o
  • Start date Start date Jul 3, 2006
89five.o
26
  • Jul 3, 2006
So I'm tired of trying to start my car with a damn screwdriver and since I've replaced pretty much everything I'm thinking about putting a push button in my car. It'll bypass my problem while I look for it and it would probably be pretty cool. What do you guys think and do any of you have a push button start? I can't figure out where I would mount it. Here's some buttons I've been looking at.
R
Reed
78
BC, Canada
Jul 3, 2006
  • Jul 3, 2006
I like the first button the best. You could maybe mount it in the right hand side of the dash under the gauges, or in the shifter bezel.
If you don't want to make a hole and you want to return to the key ignition later, maybe pop out the cig lighter and hide it away in that hole. I think that'd be the best!
Don Fiveolio
85
Houston, TX
Jul 3, 2006
  • Jul 3, 2006
The first one. Nothing like billet to bling up the car.
Put it down low by the shifter or in a secret place so you can impress your chick when you command the car to start.
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Jul 3, 2006
  • Jul 3, 2006
just wire up ur horn to be the push start!
of course... remember that its no longer a horn while ur at driving...
would hate to have that next a-hole pull out in front of you and instead of him getting the "HONK HONK" he hears the "SCCHRRECHCEHCECHCHH" of trying to start an already running car
89five.o
26
  • Jul 3, 2006
Yeah I also like the first button the most. The blue goes with the rest of my interior lights. I wanted to mount it in the area where the dummy lights are under the gauges but I dont want to make that panel useless. I like the cigarette lighter idea but I plan on putting my nitrous switches in there and I'll probably decide to keep the push button start if I put it in. Thanks for the input guys. Any other ideas?
R
Reed
78
BC, Canada
Jul 3, 2006
  • Jul 3, 2006
No way to put the start button in on the panel with the nitrous buttons? Why not mount it where the key ignition is already?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 3, 2006
  • Jul 3, 2006
Why doesn't the key work to start the car?
89five.o
26
  • Jul 3, 2006
Pretty sure it's a bad fusable link somewhere. I've changed the starter, clutch safety switch,neutral safety switch,ignition switch,starter solenoid and I think thats about it Electronics and wiring hate me! I'm definetely going to let someone else wire up all of my nitrous crap lol.
Guero
2,148
Jul 3, 2006
  • Jul 3, 2006
What would be the procedure do install one of this??????
D
Deleted member 87397
Jul 3, 2006
#10
  • Jul 3, 2006
  • #10
Yeah, if you can install one of those and a kill switch somwhere and never even have to use the key again I'd be totally up for putting on in my car. Someone on here once said that you'd still need the key for some reason even with the start button, but I don't know if they were correct or not.
M
MATREDGT
59
Shelby Twp., Michigan
Jul 3, 2006
#11
  • Jul 3, 2006
  • #11
You would still need to use the key to unlock the steering column so you could steer the car. Not sure how you would disable that, but I know you couldn't get rid of the key until you figured out how to disable the lock on the steering column.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 3, 2006
#12
  • Jul 3, 2006
  • #12
The circuit is very simple, all you need to troubleshoot it is a test light and some patience.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
89five.o
26
#13
  • Jul 3, 2006
  • #13
The key does that and something else as well. Right now I have to have my ignition in the on position and cross the solenoid (or in my case the relay since I swapped to a mini starter) for the car to start. The push button would pretty much act just like crossing the relay. Appreciate the info as well jrichker !
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
