push button to turn key?? help
84fiveohore
23
york, pa
i got this 86 stang..... they guy that had is has the wiring all bitched up... i got it on a push button now... how do i get it so i can just turn the key and go.... its a 86 gt... origional v8 car... i put an 79 351w in , 5 speed, standard duraspark distributor, standard ignition box.... stock coil ..... any help guys would be great... thanks
The S-terminal wire might have been cut and rerouted to the pushbutton. Identify the color of the output wire at the pushbutton and if it matches that of your starter interlock wire (which I don't happen to know the color of, for your 86), you can solder it back to the other cut end.
Good luck.
