  • 1994 - 1995 Specific Tech
push rod question....
  • Thread starter Thread starter MI95Cobra
  • Start date Start date Jun 19, 2007
MI95Cobra
451
Oklahoma City
Jun 19, 2007
  • Jun 19, 2007
if i get gt40x heads or even edlebrock heads will i need to change my push rod length using an e303 cam...jimmy
blkcobra50
209
  • Jun 19, 2007
Most likely those heads would retain stock length pushrods. But it's always a good idea to check if they are indeed the correct length using a pushrod checking tool. Comp cams makes a real nice piece for $20. This will allow you to get the proper valvetrain geometry.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 19, 2007
  • Jun 19, 2007
Jimmy
The big cam companies like Crane, Comp, Crower and the like, have
excellent basic info on setting up a reliable valve train no matter
what heads, or block you might use.
Makes no matter if heads or block have been milled or even if both
have been milled ... if one wants their valve train to operate like it
should ... and last ... they are gonna have to preform basic checks
to ensure all that stuff is correct.
It ain't Rocket Science
Its pretty simple stuff really
Just cause one pr length was good for one member's combo
It don't always mean the same will work for another member
who is running the same heads and block
Just look in their technical section for the info which will simply
explain all the details. They also usually have helpful illustration's
Grady
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Gt40 e303 combo questions
  • 99mustanggt2018
  • Mar 30, 2025
1994 - 1995 Specific Tech Mar 30, 2025
KRUISR
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
