Push Start
  • Thread starter Thread starter cheeks
  • Start date Start date Nov 12, 2006
1 of 2 Next Last
C
cheeks
262
  • Nov 12, 2006
Hey guys,
Just wondering what would be the easiest way of using a push button style switch to start the stang with...(I would like it so that the key must be in the "on" position, then just be able to hit the switch to start the car)...any input/help with this is greatly appreciated...
Black1987Stang
1,422
Jersey Shore
Nov 12, 2006
  • Nov 12, 2006
Its easy, run 12v power to one side of the switch and the other terminal of the switch goes to the starter solemoid....(where the little wire goes to, held onto it by a little rubber boot that slides onto a little metal threaded stud on top of the solenoid)....Just put power to that metal stud, and it will crank
HISSIN50
34
129
Nov 12, 2006
  • Nov 12, 2006
Additionally, you could grab the S-terminal wire inside the car (at the ignition switch) for a super short run of wire to your switch.
Good luck.
EDIT: If you wanted to be real safe about it, you can tap into the backside (outlet) of the clutch safety switch. This would require you to have the clutch in for the switch to work. That might save accidentally bumping the switch and engaging the starter.
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
Nov 13, 2006
  • Nov 13, 2006
Piggy backing of the clutch switch is probably the safest way to do it. Now heres the trick, A) Mount it somwhere invisible, and 2) wire the OLD links from the "start" position in your ignition switch to a "short circuit" that blows out a new fuse or relay for the ignition system. So if anybody tries to steal your car, they turn the key and, BAM the ignition is dead. But fortunately, you know where you mounted this new fuse or relay, so you can easily replace it and keep on moving.
Just an idea I had....and am working on....
Hickfied
413
Morganton, NC
Nov 13, 2006
  • Nov 13, 2006
Wow Prime. I didn't think of that! I am going to have to rewire my switch now! lol
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 13, 2006
  • Nov 13, 2006
if you did it this way will the car still crank over with just turning the key
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Nov 13, 2006
  • Nov 13, 2006
wouldnt it make it easy for someone to steal it? since you will not use the key?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Nov 13, 2006
  • Nov 13, 2006
You'll still need the key to operate the electronics, so you might be able to spin the engine with the button, but the ignition and fuel won't work. I like Prime Lord's idea, but otherwise, I think you'll get tired of it. What's wrong with just turning the key?
Mustang78
486
Aberdeen, WA
Nov 13, 2006
  • Nov 13, 2006
a push button is more racey(faster down the 1/4), haha..but a good idea if your switch is fugged up or you just wanna look cool in front of your friends i suppose
~Mark~
Prime Lord
2,137
199
114
Denver-ish
Nov 14, 2006
#10
  • Nov 14, 2006
  • #10
You still need the key to turn on the electronics and the fuel system. but the actuall engagement of the starter motor will be diverted to the button. You'd put the key in, turn it to the ON possition and then push the button to fire it up.
I can't see getting tired of it if its wired to prevent car theives. It'd be worth it.
Thats my primary reason for wanting to do it, sure the key works fine, but when my car is done at the body shop, its gonna look brand new, and its a rare car on top of that, so for security sake, I think its great.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 14, 2006
#11
  • Nov 14, 2006
  • #11
I have wanted to do this too mostly for security sake but it does look cool when your friends are around.....But I would not even show them where it is
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Nov 14, 2006
#12
  • Nov 14, 2006
  • #12
i think the hard part is finding a cool switch.
Jegs had a little plate with a push-button and another "arm" switch on it....thought it'd go good in the ash tray spot, but its been a while since i thought of doin it lol
rd
3,316
63
109
Ocean Springs MS
Nov 14, 2006
#13
  • Nov 14, 2006
  • #13
Put a home doorbell button in the lighter socket, connected to the always hot positive wire, and run the other wire to the switch terminal of the starter relay.
Turn the key to on and push the button.
I bought an old F150 from a carpenter once that had it done this way. He could wire a doorbell, but did not know how to adjust the neutral safety switch.....
Note that this does bypass the park/neutral safety and clutch safety switches, so be careful with it.
You could also just intercept the starter wire from the key switch with a pushbutton and keep those safety items.
Prime Lord
2,137
199
114
Denver-ish
Nov 15, 2006
#14
  • Nov 15, 2006
  • #14
Nobody is ever going to see the switch...so it can look like whatever as long as its functional. I think doing anything in the ashtray area is too obvious. I'm thinking under the console accessable by reaching through the opening for the parking brake OR under the seat...but tucked up on the bottom of the seat.
85ragtop
BTW, I like dudes.
475
123
NC
Nov 15, 2006
#15
  • Nov 15, 2006
  • #15
Got mine under the dash. Little chrome button, no one even sees it.
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Nov 15, 2006
#16
  • Nov 15, 2006
  • #16
I am interested in getting one to avoid theft.......Will this switch interfer with my alarm...I dont have a remote start btw.
85ragtop
BTW, I like dudes.
475
123
NC
Nov 15, 2006
#17
  • Nov 15, 2006
  • #17
With mine you still have to have the key turned. My switch is hooked to the solenoid only.
Prime Lord
2,137
199
114
Denver-ish
Nov 15, 2006
#18
  • Nov 15, 2006
  • #18
not one bit. All you're doing is bypassing the "start" position on your regular ignition switch. Basically to be an anti-theft device, after installing the switch you need to cut/disable the lines that acually connect to the "start" position so it dosen't actually start the car anymore.
HISSIN50
34
129
Nov 15, 2006
#19
  • Nov 15, 2006
  • #19
Furthermore, I liked the idea before about making the start position do something to actually disable the car. Otherwise a thief would pop the hood and jump the solenoid.
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Nov 15, 2006
#20
  • Nov 15, 2006
  • #20
I put a "push to start" button in the car and then I lent the car to a chevy guy... he read the button - got out and started to push the car.. I asked "what are you doing" he replied "hey I read the warning, my car is like that but there isn't a warning"...
ummm tap into the wire that gives power only when the key is on and tap the clutch switch like posted above... yup
1 of 2 Next Last
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
