Put my 70MM TB on...
LarsD
2,680
119
123
Texas
Wow, car feels a lot stronger, can't wait to make it to the track again. I have a slight problem. When to car is warmed up, the idle surges like crazy now. I set my tps to like .994 volts with the engine off, did I do it right? When the engine is idling, it reads at a little over a volt.
L.D.
I set mine to .998. The reading shouldn't change just because the engine is running, it should stay the same. I wonder if the vaccume is sucking it open a little. Check throttle linkage and throttle spring.
