did you run the bosch platinum +4's? i hear they add upwards of 20hp A PIECE
autolites gapped to .054 FTW, i mean... if i had a mustang that's what i'd use...
The factory gaped them, and recommends .054
Nope, stock motor craft. Now put down the "Rice HP Guide", and walk away from the table....![]()
Hmmm. So should you run a factory gap with HCI?
you could gap them a little smaller but the factory recommended gap works fine. anywhere between .048-.054 works. i think i have mine at .049 or somewhere around there.
Oh ok... I thought someone told me to gap them at like .045, but if thats not enough I will pull em back out a regap them...
you should be fine with that. is your car pinging or anything?
Not that I noticed, car runs fine, I was just curious. I just through in new plugs, wires, cap & rotor, 255lph pump, 24lb injectors, & 76mm C&L maf. Fuel pressure is set at 38lbs, but can't remember the timing, but I know it wasn't too much, maybe 14 degrees give or take?
Autolite 23s gapped to .35 ftw.
